No it's not leaking. It was torqued to spec and I used "right stuff" which in my experience doesn't let anything through. Plus, I would have mixture of coolant and oil which I do not.
Originally Posted by Bullitt390
Also, with the design of the FE, you can have an intake leak and therefore a vacuum leak and not have a coolant leak. The FE intake gaskets are finicky, especially the Fel-Pro Print-o-leaks.
Check you plugs for oil fouling. Adjust your timing properly with a timing light already.
Josh
Thank you Bullit390. The FE's are terrible for leaking gaskets. I've had to redo several, because it's so hard to get them just right. I still bet you have a leaking intake gasket. It fits the bill perfectly.
I see no sign on coolant, so what would I check? I will check the timing.
As well as a timing light or your assuming there as well.
Unless the cam is WAY radical, the 8-12 will be fine, but the vac gauge will assist in getting idle, timing, fuel mix setup correctly. Why guess at it ?
Lets see. The only thing you changed is the intake gasket and now it pings. The only two things it can be is a leak at the intake gasket or the carb gasket (if you took the carb off), or timing. Why did you change the intake gasket?
-Scouder
Well it was obviously replaced because it was leaking. This is what stumbles me. I know what a ping sounds like and this is not a ping noise. A ping described by me, sounds like popcorn popping. This is more of a chatter/clatter when going up hill in 4th gear. It does not make this noise at all any other time. There is no sign of a leak. I will get the vacuum tool.
You're right. Nice tool. I'll have to get my hands on one.
Ping will happen when under load, like going up a hill, or short-shifting into 4th gear. The biggest causes of ping are:
Too much cylinder pressure (compression)
Too low octane
Too much heat
Lean fuel mixture (which could definately be caused by a leak)
Advanced timing
Timing may become irrelevant with pre-ignition, since the fuel mixture ignites on it's own.
Ping can sound like a tic, barely noticeable over the normal sound of the engine, or in it's more common form, sound like someone hitting the engine block or cylinder heads with a small hammer very quickly. Incidentally, that is exactly what is happening to your piston top during ping. It is being hit with a very large, very high temperature hammer, and it will go through the top of the piston if it is done long enough. One second is enough in a highly tuned race engine to make a compression release in the top of a piston.
If you determine that you don't have a leak, and you don't have a timing problem, then do a test and put in a full tank of premium fuel to see if it goes away.
Kinda like shaking a coffee can full of marbles, right? It sounds like pretty severe pinging. It's the carb gasket or the intake gasket. Fix it or you'll end up with advanced engine wear, burning holes in pistons, cracked pistons, overheating and associated problems such as cracked heads, cracked/broken ring landings. But the good thing is your exhaust pipe will be as clean as the metal it's made of, no soot at all.
I might try putting in better gas and see what that does as a good test but I will retard the timing and see what that does as well.
I am going to bet that neither fix the problem.
It didn't need high octane fuel before, and the timing was fine at factory spec before, so why would changing the intake gasket change that? I'm afraid you'll be taking your intake off and redoing it.
Hey 1974SuperCabF250. Did you happen to read the postings? He has said that he timed it by ear! The dizzy has to come out to change the intake on a FE so it could very well not be set to Factory settings.
I would get a timing light and set it properly myself but until you do it would be wise to retard the timing a bit so you dont damage anything. It could still be numerous things making the noise but I would do that first and then see if i could detect exactly where the noise is coming from.
Heres a new idea how about the rocker arm bolts, did you get them mixed up? There is one certain bolt that goes in a certain hole that controls the oil flow to the rockers. Wrong bolt=little to no oil=valve chatter.
The cheap way to check for a vacuum leak, get a can of starting fluid or brake cleaner and spray around the intake and carb base. If you have a change in idle, theres your leak.
Get a timing lite on it right away. Set it to stock specs right away! Your timing may be too far advanced which causes damage, or it may be too restarted. I time by ear too, but I start out at the 8 deg. BTDC and go from there, advancing it little by little until it has too much.
I retarded it a little bit and she's running perfect. Like I said, I was pretty sure it wasn't a leak since I sealed the crap out of it. I'll run it like this for a while and see how she runs.
