Odd Oil leaks
Old Feb 12, 2009 | 02:01 PM
74baja's Avatar
74baja
Odd Oil leaks
Hi all,
I was under my truck looking at the steering stabilizer, when I noticed that it was damp with oil. So was the steering linkage above it and the front of the oil pan. Where is this leak coming from? I did take the HPOP resevior cover off when I was replacing the EBPS. I thought I sealed it pretty well with RTV silicone, but could this be the source of the leak?
Thanks
Old Feb 12, 2009 | 02:02 PM
Izzy351's Avatar
Izzy351
Sure could. Clean it up with some SimpleGreen or your favorite degreaser and see if you can see the source.
Old Feb 12, 2009 | 02:04 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Why did you take the HPOP cover off when you changed the EBPS?
Old Feb 12, 2009 | 03:40 PM
74baja's Avatar
74baja
I looked closer, and I was 99% sure that was the leak source, so I removed it. Now I'm cleaning up the flange. I was using Permatex Gasket Remover. Do you think if a little spray of this stuff got in the hole it could do damage to any internals?
Rick, I had to remove the cover because I bent it while removing the old EBPS... long story. Maybe I'm not calling it the right name, its the oval shaped cover/bracket that the EBP tube and EBPS are connected to.
Thanks
Old Feb 12, 2009 | 04:13 PM
brian42's Avatar
brian42
Veteran: Navy
Are you sure it's oil? It could be fuel mixing with the grime on the engine block. When my fuel bowl drain valve started to leak it dripped down the passenger side of the engine directly onto my stabilizer before pooling on the ground.
Food for thought...
