1978 - 1996 Big Bronco
Aod for 86 bronco
Old Feb 11, 2009 | 07:58 PM
the bull 1986's Avatar
the bull 1986
Aod for 86 bronco
Does anyone know what year model aod will fit the np 205 transfer case my bronco is a 1986 with a 5.8 and 4 speed with low first and reverse. I need to put an overdrive in it.
Old Feb 12, 2009 | 08:39 PM
NWBronco's Avatar
NWBronco
The AOD never came behind the 5.8L. It was only behind the 5.0L TO get it bolted up to the 5.8L, you'll need the flyweel form the 5.0L the AOD came from.
If it's a Ford transfer case, it should bolt to the adapter on the back of the AOD. The AOD came with BW1345 and NP208. I've got a BW1356 on the back of mine right now.
Old Feb 12, 2009 | 09:31 PM
Conanski's Avatar
Conanski
Actually the AOD did come behind the 5.8.. in a Crown Vic, so the correct flexplate is available used and new. The 5.8 is also a 28oz imbalance while the 5.0 was 50oz after 1981, so you want to get the correct flexplate for it to avoid a vibration problem.
jack048307
Jul 2, 2008 01:51 PM
Silver Bronco
Dec 15, 2003 06:34 AM
nechun
Dec 3, 2003 09:13 PM
Traveller_NC
Jan 13, 2003 04:59 PM
Mulletwagon
Bronco II
Jan 20, 2000 03:20 PM
