Tranny Coolant Line Question
Old Feb 11, 2009 | 05:59 PM
anojones's Avatar
anojones
I'm replacing my radiator, and can't get the lower transmission coolant line off the radiator- rusted on. I've kinked the tube a little (not too much) but still can't get the thing off after PB Blaster etc and the nut is starting to strip. Can I just cut the metal line and patch in some rubber hose with hose clamps? I figure I can get the cut stub of the coolant line out of the radiator easier once it's out of the truck. Thanks for any advice.
Old Feb 11, 2009 | 11:37 PM
geez768's Avatar
geez768
thats how alot of aftermarket trans coolers hook up, did it on my last truck with no prob at all.
Old Feb 11, 2009 | 11:55 PM
flamebuster's Avatar
flamebuster
same here, even used vice grips to wrangle the nut. aux coolers use rubber hose and clamps.
Old Feb 12, 2009 | 12:22 PM
Ford Breakdown's Avatar
Ford Breakdown
Rubber hose patch is pretty common, but make sure you pay extra for hose rated for transmission fluid: gas and vaccumm line will rot out quickly.
Old Feb 12, 2009 | 01:53 PM
anojones's Avatar
anojones
Thanks- that will make it much easier once I finish rounding off that nut with vise-grips
Old Feb 12, 2009 | 05:47 PM
themoparkid's Avatar
themoparkid
If you search your auto parts online, you can get a line fitting kit. Thats what I did when I replaced my radiator.
jhaas63
15
Nov 26, 2012 03:46 PM
jonesg
Aug 24, 2011 05:31 AM
mktsc
31
Nov 28, 2010 02:22 PM
