Flutter problem
Old Feb 11, 2009 | 05:27 PM
Khart's Avatar
Khart
Flutter problem
I'll try to explain this as simple as possible. fficeffice" /><O></O>
<O></O>
2003 SD F350 4X4 CC 7.3 running edge J/A. As I'm driving with cruse on once in a while i feel a flutter almost like the cruse turned off and back on (gauges would not pick up drop in RPM or Temp). This isn't enough to shut down the cruse but enough to feel it. I checked for codes and there were none, I installed new glow plugs Because I was having a hard to start and lots of smoke on cold mornings. Once in a while at start up and take off it would really struggle to run smoking and once in a while popping. I'd pull over and let it warm up longer but it didn't seam to help. After a few miles and it heated up it would run fine. Once I cleared the smoke it would have plenty of power and run fin. I do run Lucas injector cleaner in fuel most of the time.
I purchase a Cam Postion Sensor just in case but haven't installed it yet.
What do you all think??
Old Feb 11, 2009 | 05:50 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Cam sensors will make it do some funny things. I believe I would start there.
Old Feb 11, 2009 | 06:08 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have you tried putting it back to stock? Take the edge off and see if anything changes.
Old Feb 11, 2009 | 06:32 PM
DieselCamper01's Avatar
DieselCamper01
Is the Lucas injector cleaner a possible issue? Is it ok to use in diesel? Just asking.
Old Feb 12, 2009 | 11:20 PM
Khart's Avatar
Khart
installing cam sensor tomorrow. seams like it only happens when cold. let you all know what happens.
Old Feb 12, 2009 | 11:44 PM
CampSpringsJohn
I believe the lucas injector cleaner works for both gas and diesel engines, but I could be wrong.
Lucas make an injector lubricant for diesels, perhaps that's what he was talking about.
Old Feb 13, 2009 | 07:04 AM
Khart's Avatar
Khart
Can the CPS be a problem and it still not throw a code? By the way had codes checked at AutoZone with hand held, not sure how reliable they are. If the CPS doesn't fix it I'm going to have to take it in to a dealer $$$$ to hook it up on there machine.
Old Feb 13, 2009 | 07:15 AM
megawatt00's Avatar
megawatt00
The code readers that they have at Autozone will read some of the codes on our trucks but not all of them. These engines were built by International and are not OBD 2 compliant
Old Feb 13, 2009 | 07:24 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
that sounds just like what mine did when the 2nd CPS went bad just a stutter then......
post back after replacing the cps and let us know how it goes!
Old Feb 13, 2009 | 09:19 AM
Khart's Avatar
Khart
Thanks guys for all your help, great site. I'll post how it goes.
Not sure if this has anything to do with it but both times it was hard to start, smoking, and a backfire pop I was low on fuel in tank (low fuel light on). Is there a pump in tank to push to IP that could be getting week and I'm running injectors low on fuel?
Old Feb 13, 2009 | 09:43 AM
DieselCamper01
No stock intank pump unless someone added it before you bought the truck
Old Feb 13, 2009 | 09:58 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
True but if the pickup is just a tad bit higher than it should be, this could lead to a fuel starvation issue. Not likely, but possible. You said that after it warmed up fully it ran fine. What outside temps are we talking about here? When was the last time you changed your fuel filter?
Old Feb 13, 2009 | 10:06 AM
Izzy351's Avatar
Izzy351
Also, the stock pickup has that PITA auxiliary pickup duck-bill looking thing on the side. If it's leaky and the fuel gets below that level, it can suck air.
Old Feb 13, 2009 | 12:03 PM
Khart's Avatar
Khart
Ford dealer is showing inline pump on frame and a tank pump. We did install the CPS with no change. Opened up the fuel filter lid and air farted out. Turn the key on and you can hear the inline pump continuously pumping and not shutting off (this is new). Unpluged inline pump and hear nothing from the pump tank.
This might explain the slight flutter from time to time running down the road. Starving for fuel.
Does anyone know if the tank has to be dropped or can it be changed with tank on?
Old Feb 13, 2009 | 12:28 PM
Khart's Avatar
Khart
Just changed fuel filter
CPS on and no start and no change.
Ford is showing 2 pumps. One inline along frame and one in tank ($500.00). Turn the key on and can hear the inline one along frame running not shutting off. Unplug it inline pump and hear nothing coming from pump in tank. Opened up the fuel filter lid and air farted out, sucking air.
Izzy - PITA and duck-bill. What is this and where is it located.
