Flutter problem
Old Feb 13, 2009 | 01:07 PM
Phrosut's Avatar
Phrosut
I have an '03 7.3 and although not 4WD, I DO NOT believe there is another fuel pump in my tank. Only the rail-mounted. Of course, I haven't had the tank down to look inside. I'd be running your tank at higher fuel levels and see if that doesn't remedy your problem.... getting the air when you opened the filter sure indicates that you've been sucking air somewhere.
Phil
Old Feb 13, 2009 | 03:12 PM
Khart's Avatar
Khart
Want to check the reply before I go dropping the tank. Anyone know where the reply might be for the tank pump?
myakkacracka
13
Jun 16, 2016 11:33 AM
Jesser02EX
35
Jul 14, 2014 12:17 PM
kontoboy
Sep 12, 2010 10:58 PM
chuck362
Nov 5, 2009 11:28 AM
Khart
15
May 3, 2009 09:02 PM
