Sponsored by: Real Truck
Super Duty Rake..?
Old Feb 11, 2009 | 05:19 PM
KTNC's Avatar
KTNC
Super Duty Rake..?
I'm interested in upgrading from an F150 to an F350 diesel for towing. However, I'm concerned about the lack of a "rake" on the some super duties (the level look, as opposed to the high in the back look that the F150s have) I prefer the raked look, is the level look caused by the heavier front springs..? Is this something that can adjusted..?
Old Feb 11, 2009 | 05:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sure, you can adjust it. Use an Add-a-leaf, airbags, taller block or new spring pack.
Old Feb 11, 2009 | 05:34 PM
jdboy's Avatar
jdboy
A very cheap and easy thing to do is to go to your local wrecking yard and get a set of stock F350 rear blocks. That alone should be good for an aditional 2" of rear lift.
Old Feb 11, 2009 | 06:11 PM
mstiles19's Avatar
mstiles19
this works if you have a f250 but it would not work if you already have f350(like the OP wants to upgrade to). Anything over a 4 inch block is risky and NEVER stack blocks. i would recommend going with airbags because they are adjustable so you can soften them for when your truck is unloaded. For a cheaper way you could do add-a-leafs but your ride will always be a lot stiffer.
if you have any air bag questions feel free to ask
Old Feb 11, 2009 | 07:12 PM
ken kenmnedy's Avatar
ken kenmnedy
if you get a f350 they all have the rake dont they I just put the 350 blocks in mine because of the nose high with the x code springs that extra 2 inches makes it look just fine
Old Feb 11, 2009 | 07:42 PM
jdboy's Avatar
jdboy
Red face
Good point, I've got to start reading more closely or stop leaving the room before finishing a post! LOL
Old Feb 11, 2009 | 09:13 PM
Jbrown8988's Avatar
Jbrown8988
airbags! 250 bucks!
Old Feb 12, 2009 | 02:22 PM
dualwheels66's Avatar
dualwheels66
Just get the F350 and the highest GVW which is 11,500 for a diesel and the crew cab. Done.
Old Feb 12, 2009 | 04:32 PM
Sooper-Doodie's Avatar
Sooper-Doodie
Regardless of engine, the GVW is the same.
Old Feb 12, 2009 | 06:59 PM
dualwheels66
The diesel has a GVW of 11,500lbs. and the V10 has a GVW of 11,200lbs. both being crew cabs and long beds.
Old Feb 12, 2009 | 11:03 PM
c.f.moore's Avatar
c.f.moore
Depending on what you are towing, too much "rake" could pose problems with the trailer. Remember, a trailer tows best while level or slightly nose down.
good luck
Old Feb 13, 2009 | 12:23 AM
GregsSD's Avatar
GregsSD
Most Superdutys have quite a bit of rake to them when they are stock.
Levelling kits are very popular for the Superdutys to raise the front up so it is level with the rear. The Superdutys that you have seen that looked level probably had a levelling kit installed on them.
My 05 F-250 4x4 sat 2-1/2" higher in the rear when it was stock and the F-350's are even higher in the rear.
Old Feb 13, 2009 | 01:25 AM
akford351's Avatar
akford351
AAL or airbags...
I prefer the raked look of around 2" or so. The body lines on these trucks make them look @ss low when level.
Old Feb 13, 2009 | 04:51 PM
KTNC's Avatar
KTNC
Thanks for all the replies... Yes I'm very interested in air bags, how they work, etc. I would like an F350 SRW diesel short bed for a towing between 14,000 - 17,000 lbs. I don't want a dualie because when the truck is not towing it will be used as a pick up, including off road.
I still have to say, though, I'm not talking about after market leveling kits, these trucks are brand new and on the dealer's lot. I even saw 2 brand new F450's one had a nice rake and the other one was level..?
I'm not looking for a rake when it's hooked to the 5th wheel, just level. What I can't stand, is the too high in the front look when hooked to a trailer, it makes the truck look weak in my opinion.
Thanks again for all the replies and any other information would be appreciated; or website links, etc...
Old Feb 13, 2009 | 05:16 PM
rudedogii's Avatar
rudedogii
I here you! Most guys that install leveling kits dont haul much.
Most heavy trucks are desinged for the maximum carrying capacity and have some "rake" when empty. Thease trucks are made for work! Thats why Ford makes the Superduty.
The F-150 is made more for going to the market. We use both trucks at work. The F-150 is a great truck when you spend an hour or two in LA traffic. But for heavy hauling you can bet the Superduty!
