390 valve train timing/torque specs
Old Feb 11, 2009 | 04:15 PM
400944's Avatar
400944
i recently was wondering why my truck keeps backfiring
through the carb
even after the timing chain change it still backfired through the carb
here is what i found once i reset the engine to TDC i noticed that the intake valve was not seated so that explains the back fire
all pushrods are new and straight
my ? is this how much or what reference do i use once i tighten down this valve train assy so i dont have open valves where they shouldnt be
thanks
Old Feb 11, 2009 | 09:16 PM
vetteracer92's Avatar
vetteracer92
two choices are new shorter pushrods or adjustable rockers. have you had the heads milled at all? mayby the pushrods are too long.
Old Feb 12, 2009 | 01:23 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Do you have the sheet metal oil deflectors under the rocker shaft pedestals?
tkisling
17
Dec 22, 2016 10:45 PM
BrushPopper
21
Jul 29, 2016 11:29 AM
Buyerz
Jul 11, 2016 12:37 PM
ColtonMullis
38
Dec 11, 2015 01:00 PM
ArcticRanger
4 Cylinder Engines
Apr 9, 2004 10:12 PM
