What will cause valve/lifter/pushrod failer?
Old Jan 21, 2014 | 07:56 PM
ColtonMullis's Avatar
ColtonMullis
So for the past month i have been working bugs out of my truck. I got most of then out and was getting ready to start driving it and it started to get a constant exhaust backfire and a carb backfire. It was happening on the same two cylinders every time. Then i noticed i had a louder than usually tick coming from the top end. So i pulled the valve covers and pulled some of the pushrods to see if i had bent one. I then noticed at the metal shavings in my oil. Im thinking i might have had a lifter seize up and bend a valve. i haven't pulled the intake yet though to look at them. Any pointers?
Old Jan 21, 2014 | 09:39 PM
Conanski's Avatar
Conanski
What year is your truck? If it's got a flat tappet motor the cam has probably eaten a lobe or two.. these things need a ZDDP additive in the oil now because the oil companies have completely eliminated zinc from modern oils as all newer motors use roller cams.
Old Jan 22, 2014 | 08:50 AM
ColtonMullis
its a 76 302
Old Jan 22, 2014 | 10:11 AM
Conanski's Avatar
Conanski
Unless its been modified that motor has a flat tappet cam.
Old Jan 22, 2014 | 11:34 AM
baddad457's Avatar
baddad457
You've got a wiped cam lobe (or two). If it's a fairly new cam, then poorly machined lifters are the primary cause of this. A poorly machined lifter bottom will prevent the cam lobe from setting the lifter in motion (rotating the lifter in it's bore), this in turn will drastically shorten the lifte of both the lobe and lifter, in as little as the 20 minutes it takes to break-in the cam. Lack of ZDDP can shorten the life of the cam and lifters, but this will happen over a long period of time and to all the lobes and lifters, not just one or two.
Old Jan 22, 2014 | 01:30 PM
ColtonMullis
That's what i was afraid of. i guess I'm going to have to pull the intake to cheak out the lifters. Does this happen overtime or could it be caused by something i did.
Old Jan 22, 2014 | 02:54 PM
ColtonMullis
the pushrods are suppose to spin right? All of them spin except one when the motor is running
Old Jan 22, 2014 | 06:35 PM
matt.likes's Avatar
matt.likes
um no. from the engines ive built and the ones we have had in the shop pushrods are not suppost to spin, which means either your cam/lifters are loosing metal, or your pushrod length is too short, or your valve lash is incorrect, or if your lifters are hydraulic lifters then they may be collapsed and will need to be replaced.
Old Jan 22, 2014 | 06:40 PM
JWC 3's Avatar
JWC 3
Um yes . They will slowly rotate while running .
Old Jan 22, 2014 | 07:44 PM
baddad457's Avatar
baddad457
X2, the motion of the lifter sets the pushrods into rotataing as well. Roller cammed engine's pushrods do not spin, flat tappet pushrods do.
Old Jan 22, 2014 | 07:51 PM
baddad457's Avatar
baddad457
If it was a bad lifter, the only thing you did "wrong" was fail to inspect all of the lifters before dropping them in their bores. Also should have made sure they rotated freely in the bores azs you dropped them in. Worn lifter bores can also prevent the lifter from rotating. You're not the Lone Ranger here, I've had two cam failures that each had a single lobe/lifter fail. You're just one of many, many victims of failures of the past ten years, so don't beat yourself up. One was a Crane cam, the other a Comp cams. I'm 90% certain both may have been bad lifters with poorly machined bottoms. Too much moly lube on one lifter's sides could also have done the deal, the other could have been the cold temps at startup (low 30's, & thick 30 weight oil) If that lifter has worn to the point where the lifter has a new oiling hole in it's bottom, the cam lobe is toast and the whole cam will need to be replaced. You could drop a good lifter in there and rotate the crank and compare the lift it generates now to decide on whether the cam s toast, chances are it is.
Old Jan 22, 2014 | 07:52 PM
ColtonMullis
my first rod on cylinder 5 spins pretty fast and the first rod on cylinder 6 barely turns(only a little bit at a time)
Old Jan 22, 2014 | 07:55 PM
baddad457's Avatar
baddad457
Differences in the rate of rotation can be due to differences in lifter preload. In any case, you likely will need to replace the cam and lifters.
Old Jan 22, 2014 | 08:05 PM
JWC 3's Avatar
JWC 3
Agree . Measure lift and adjustment . Go from there .
Old Jan 22, 2014 | 08:20 PM
ColtonMullis
do would it backfiring and not jumping rpms in gear be a symptom of that.
