Sponsored by: Real Truck
Door locks going crazy
Old Feb 10, 2009 | 07:20 PM
meanv10's Avatar
meanv10
My door locks are going nuts.
when i got in my truck tonight i locked the doors after i started it. 2 seconds after I heard them unlock, so i locked them then they unlocked again, Only the drivers side is doing this.
So when I got home I shut the truck off and tried the power locks again, they worked fine, so i did it a few times and everything was normal. Then I turned the ignition on and they started acting crazy again.
so whenever the power is off they work fine but when the ignition is on they go crazy.
Any Ideas?
And its still making that crazy sound that i posted about a few days ago.
Old Feb 10, 2009 | 07:47 PM
ReAX's Avatar
ReAX
My 02 will not power lock the driver's door while running. The rest act normally. How are your dome lights acting?
Old Feb 10, 2009 | 09:01 PM
meanv10's Avatar
meanv10
The door ajar light is on, that is a recurring problem so I just took the dome light out. If nobody has an Idea Im going to attack it this weekend with a volt meter and try the Wd40 in the door sensor thing, I was just hoping someone had an esay fix. I just got my shift kit in the mail and wanted to do that all day sat.
Old Feb 10, 2009 | 09:07 PM
ayden2004's Avatar
ayden2004
it may not be locking the doors because it thinks you are locking the keys in the ignition. sounds like your door latch is having an issue. my 01 250 has the switch in the latch of the door. everyonce in a while I have to drown it with lithium grease to get the switch to make the connection so my door ajar light will shut off. I don't have power door locks. so I can only assume that if I did when I was having the ajar issue it would of done the same thing
Old Feb 11, 2009 | 07:59 AM
jonrjen's Avatar
jonrjen
Try the WD-40 fix first. I had a truck that did this same thing with the locks. Only mine would also turn on and off the interior dome light as an added special feature. Ford replaced the door sensors, which didn't do the fix. They then replaced a wire loomed relay under the dash where all the door sensors ran through....and problem cured.
Good Luck
Old Feb 11, 2009 | 09:11 AM
meanv10's Avatar
meanv10
Good Luck
So is it sprayed right in the latch itself?
Old Feb 11, 2009 | 11:22 AM
jonrjen's Avatar
jonrjen
Spray the latch as well as around it. There is a post here on the forum, showing a photo of the exact spot, however I couldn't find it to post a link. But do the latch paying special attention to the moving piviot and contact points and behind these areas. Don't get carried away and soak everything down just because it is behind the door panel. Also spray and clean the catch mounted on the door jamb.
Old Feb 11, 2009 | 12:06 PM
ReAX's Avatar
ReAX
Because of the dome light issue, I'd expect you to loose power door locks anytime. I had a similar issue and it was the VSM dieing. When it died, I lost power door locks, the dome lights stayed on until the battery saver kicked out. I replaced the VSM, but I still need to get it properly programmed. My dome lights stay on, it thinks the doors are open unless I open both fronts, and the rear doors don't trigger the dome lights.
Old Feb 11, 2009 | 02:11 PM
Beerstalker's Avatar
Beerstalker
Spray your door latches like this.
Then open and close the doors a few times. This will most likely fix both of your issues (the truck thinks your door is open with the keys in the ignition so it tries to prevent you from locking yourself out).
Old Feb 11, 2009 | 08:31 PM
meanv10's Avatar
meanv10
thanks fellas
dolphans1
Jun 25, 2017 03:31 PM
onadraw
Apr 18, 2017 11:18 PM
fordtruck661
13
Jan 22, 2017 10:05 PM
unclejtl
Feb 5, 2016 03:53 PM
fruitcake1234
Oct 15, 2013 06:04 PM
