Starter alignment
Old Feb 10, 2009 | 02:09 PM
2pazr's Avatar
2pazr
Starter alignment
the teeth on the starter should align with the flywheels teeth how? should there be a slight gap between them? im installing a new one that is suposed to be the convertion equlivalant and when i look though the hole in the bellhousing it looks like there is a little gap as the old starter never left the flywheel but i cant see the alignment/gap spacing with the old starter on because the recoil blocks my veiw.
Old Feb 10, 2009 | 02:27 PM
sdetweil's Avatar
sdetweil
engine?
on SBC there are shims to use between the starter and block..
on my 302 or 460, no adjustment available.
sam
Old Feb 10, 2009 | 03:00 PM
2pazr's Avatar
2pazr
i have a 292 y block and i dont have an adjustment eaither i just have the stater sitting installed in the bellhousing i just dont wanna turn it over and possibly shred the teeth on something. is there play between the gears or when engaged the teeth should be snug with the flywheel?
Old Feb 10, 2009 | 03:06 PM
sdetweil's Avatar
sdetweil
we'll have to wait for one of the experts about the stock engines.. I've got no clue.
sam
Old Feb 10, 2009 | 09:24 PM
jm ray's Avatar
jm ray
mark or paint a few teeth on the ring gear and give it a try. then look at painted teeth. it should be 3/4 as deep as the teeth and all the way across foom front to back. if it sound good , then its most likley good to go. i use a product called persuasion blue to check this but paint should work well also.
Old Feb 11, 2009 | 12:16 AM
2pazr's Avatar
2pazr
well i cant send it back if its used so i have it bolted up with plastic protecting it. i can see staight inside and the teeth on the starter look like they only go in between 1/2 - 3/4 closer to the 1/2 the depth of the teeth it looks like the meatier part of the teeth will make contact i just dont want to round the teth on the starter. is there any way to turn the flywheel by hand with the transmission off
Old Feb 11, 2009 | 06:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the 292, and what year is the starter?
There are different Y Block starters and different starter drives.
Old Feb 11, 2009 | 01:00 PM
2pazr's Avatar
2pazr
it came out of a 57 tbird and the starter year is unknown but every thing aligns up on the bolts also with the flywheel. does any one know what the correct starters will fit if this ones not right i can return it for the right one .
obscurity
Sep 14, 2015 07:01 PM
oneofakind97
Nov 15, 2014 08:26 PM
Funke1
Sep 21, 2014 07:37 AM
orthogod1
Dec 28, 2010 06:35 PM
vin545
25
Jan 23, 2007 12:45 AM
