2000 power stroke mod questions
Old Feb 10, 2009 | 01:59 PM
2000POWERSTROKE's Avatar
2000POWERSTROKE
help!!! I have a 2000 f250 psd, there are so many different tuning mods out there it is difficult to choose the right one. So far i have done the 6637 mod, i will be doing a 4 inch turbo back exhaust straight pipe (no muffler) next week. The last thing i want to do is a programer or a chip, i have read about the edge evolution, super chips cortex, dp tuners, ts performance, banks etc... So what do you guys recomend? Thanks
Old Feb 10, 2009 | 02:01 PM
smoky_diesel's Avatar
smoky_diesel
DP buddy, DP tuner.
Old Feb 10, 2009 | 02:03 PM
brian42's Avatar
brian42
Veteran: Navy
Gages...then DP Tuner...
Old Feb 10, 2009 | 02:07 PM
superduty4x4's Avatar
superduty4x4
What he said.
Old Feb 10, 2009 | 03:22 PM
gdn's Avatar
gdn
I went thru the same thing when I got my truck, looked a lot of info on chips and took the advice of most here - DP tuner. I have no regrets whatsoever! Too many people have all the others and switch to DP and can't believe the difference.
Old Feb 10, 2009 | 05:44 PM
Phrosut's Avatar
Phrosut
Count me among that minority that DIDN'T follow the popular advice and buy DP. I got an Edge Evolution II because: 1) I needed gauges 2) I wanted a tuner and 3) I wanted something that could read and clear codes. It does all that, tho the "tuner" part is not as good as DP's. I was willing to live with the tuner because I could always add a DP later and I'd still have the gauges and code reader.
What I recently learned wouldn't be a significant problem for most: the Evo has a current draw of 90 milliamps when the truck is off. I go for weeks sometimes between trips using this truck and combined with some other little current phantom "leaks" (another 90ma for a total of 180ma) , my batteries (new) don't have enough juice to start the truck after sitting for two weeks (not unusual for me).
For now, I'm leaving the Evolution disconnected (it just plugs into the OBDII port) until those times I'm towing and need the gauges. Not a big deal but an inconvenience.
On hindsight, I wish I'd bought a set of pillar gauges and a DP. And something to read and clear codes. A set of pillar gauges wouldn't be sucking up battery juice when the truck is parked.
Phil
Old Feb 10, 2009 | 05:54 PM
4inchlovin's Avatar
4inchlovin
DP Tuner im saving for mine right now...
Old Feb 10, 2009 | 06:43 PM
2000POWERSTROKE
Well, that was an easy decision, i guess its dp all the way, thanks guys. I can't wait to order it... Anybody know the horsepower and torque gains with the dp tuner, the 6637 air filter mod, and a 4 inch turbo back straight pipe?
Old Feb 10, 2009 | 07:10 PM
blakeusa's Avatar
blakeusa
On the DP there appears to be many programs you can run and it looks like you buy those programs al la carte. If this is correct what programs are people running.
Think im sold on the DP after reading many posts on this-- the edge looks cool and has gauges-- but performance comes first for me.
Old Feb 10, 2009 | 07:21 PM
triskit16's Avatar
triskit16
Ive got superchips right now...only reason is because I havent been able to save properly for the DP! If I sold it I could do it easily but I will keep it for a code reader...
DP all the way though. I dont think Ive read anything negative about them since Ive been a member here!
Old Feb 10, 2009 | 07:29 PM
2000POWERSTROKE
Thanks man, i appreciate all of the feedback, for codes i have been using an actron obd ii code reader so far it works great... They are pretty cheap at sears, autozone etc... I think i paid like $150 bucks
Old Feb 10, 2009 | 07:32 PM
2000POWERSTROKE
Originally Posted by blakeusa
on the dp there appears to be many programs you can run and it looks like you buy those programs al la carte. If this is correct what programs are people running.
Think im sold on the dp after reading many posts on this-- the edge looks cool and has gauges-- but performance comes first for me.
i was told to run a 60hp tow 80hp econ for mpg 120hp race along with no start and stock programs. I was thinking of adding the high idle
Old Feb 10, 2009 | 07:34 PM
triskit16's Avatar
triskit16
Just make sure they will pull the diesel specific codes. A lot of the big named readers wont read the codes on our trucks properly or at all. But Im no expert on which ones will or wont read ours!
Old Feb 10, 2009 | 07:39 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
Get the DP tuner from Jody and Dianne. DO NOT confuse the DP tuner with the Diablo Predator....taint the same!!!!!!! DOH!
Old Feb 10, 2009 | 08:56 PM
4inchlovin's Avatar
4inchlovin
Sounds pretty solid to me... Stock and No start are free. Go ahead and add a high idle if ya need to. I probably wont just because if you really want to you can put your EBPV on a toggle switch and use that for high idle. Thats my plan.
Are you getting/do you have gauges???
