Aerostar Ford Aerostar
Speedometer sensor replacement problem
Old Feb 10, 2009 | 01:11 PM
Two99Point80's Avatar
Two99Point80
My mechanic replaced the speedometer sensor in my '95 Aerostar, trying to make the ABS warning light go out. The replacement part he used was a Duralast SU2175. After that, the speedometer would jump wildly over about 60 mph and the cruise control was very erratic. Reinstalling the original sensor brought things back to normal.
The factory part had a round pickup head; the Duralast was finned. Don't know what catalog might have shown it as a replacement. My guess is it didn't pick up a strong enough signal, so at higher speeds it triggered erratically.
Hope this info keeps someone else from making the same mistake
Old Feb 10, 2009 | 03:58 PM
xlt4wd90's Avatar
xlt4wd90
That sensor should still be available from Ford, so I would check with your local dealer (if he's still in business).
Old Feb 10, 2009 | 07:57 PM
Two99Point80
It's just a 2-wire sensor, so there's only one signal coming from it. Since the speedo and CC are okay again, the ABS fault must be elsewhere...
Old Feb 10, 2009 | 11:53 PM
96_4wdr's Avatar
96_4wdr
the later model Aero RABSII system appears quite simple but has multiple fail points that will cause the Idiot RABS ABS or Brake light errors
best to get a Ford Svc CD for your year as a starting point. has detailed step by step troubleshooting and detailed system description with all the interdependencies.
i've posted much of it over the years on this forum.
have you read the RABS controller error codes?
Old Feb 11, 2009 | 11:15 AM
dougielx's Avatar
dougielx
To make the abs light go out forever use black electrical tape
Old Feb 11, 2009 | 11:52 AM
Pablo-UA's Avatar
Pablo-UA
ore remove a bulb
jbwilli
Jun 3, 2023 10:38 PM
jdcrew
Apr 29, 2011 11:57 AM
paneltruck
Aug 16, 2010 09:33 AM
gossett.air
Aug 15, 2010 04:48 PM
jemlota
Jan 3, 2010 12:00 AM
