Not Very Important
Old Feb 10, 2009 | 12:25 PM
CharGriller's Avatar
CharGriller
Not Very Important
The shift **** came off in my hand on my new (used) pickup so I went out with some Locktite brand adhesive to put it on more or less permanately. When I pulled it off I noticed what looked like a screw hole in the end of the shifter stick and looking down inside the **** I noted a small hole also?
Looking at the top of the **** at the embossed six speed shift pattern it appears the top may be an insert that could be pried/popped out? If so does anyone know for certain that the **** is attached by popping the insert out and screwing the **** to the stick?
I don't want to go prying on it to find that by breaking it ...it isn't meant to come out. If it does come out any mechanics know the screw size to use? Is there any harm you can think of if I do use an adhesive?
Old Feb 10, 2009 | 12:41 PM
superduty4x4's Avatar
superduty4x4
Clay- lock-tite or Bondo it on and be done with it. As far as I know they are press fit from the factory, no screw. I've seen the shift pattern inserts spin sometimes, but I've never seen one come out- like you I'd hate to mess it up trying to pry it out.
Old Feb 10, 2009 | 12:44 PM
redfire42's Avatar
redfire42
My F150 was the same way and did the same thing. Lock-tite did the trick.
Old Feb 10, 2009 | 12:48 PM
CharGriller
Thanks fellas....it's gonna be a done deal!
Old Feb 10, 2009 | 01:16 PM
Go COugs's Avatar
Go COugs
I used JB Wield because that is what I had on hand. And I have watched my insert close enough to know that it rotates 1 rpm per mile on the freeway. Just FYI
Old Feb 10, 2009 | 01:54 PM
F350-6's Avatar
F350-6
I used a rubber mallet to re-install it down on the splines. Pressing it on by hand never seems to work. The rubber mallet trick has held up for 2 years (unless you've tried twisting it on and have stripped the plastic teeth inside the ****)
atomicjoe23
28
Jul 12, 2015 06:52 PM
sailorman3
Nov 30, 2011 08:07 PM
ChrisAdams
Sep 5, 2011 01:19 PM
pacearrow
Oct 10, 2009 09:50 PM
tjcanno
1983 - 2012 Ranger & B-Series
Mar 27, 2003 04:55 AM
