Beans brass donut gaskets
Old Feb 9, 2009 | 09:12 AM
BENG0924's Avatar
BENG0924
Anyone tried these from Beans or heard anything good or bad on them. I may go ahead and do mine since I have the turbo off and have a small leak already.
Old Feb 9, 2009 | 09:13 AM
guthrie&co's Avatar
guthrie&co
never heard of it
Old Feb 9, 2009 | 09:19 AM
03_PSD's Avatar
03_PSD
are you talking for the up-pipe?
Old Feb 9, 2009 | 09:22 AM
BENG0924's Avatar
BENG0924
Yah, Im talking about the up pipe donut gaskets that beans has on their website. I guess I prolly sholdve mentioned that in my first post.
Old Feb 9, 2009 | 09:23 AM
Kwikkordead's Avatar
Kwikkordead
I would steer clear of a solid ring for the up pipes.
My reasoning for that is I think it will anchor the upper part of the pipe in place in that flange and then that leaves no room for expansion and contraction of the up pipes.
What that will result in is that it will push up HARD on the back of the turbo and I am afraid that it might break the turbo pedastal in half or something equally as disastrous.
We all know that the bellowed up pipes are the best solution, but not everyone has the $$$ for that right now.
If I were in that position I would simply get the factory style gaskets. They allow a little bit of "slip" and that will eliminate the potential for breaking something.
Old Feb 9, 2009 | 09:40 AM
BENG0924's Avatar
BENG0924
Thank for the input. Where can I get stock gaskets for best deal.
Old Feb 9, 2009 | 11:30 AM
rbaker6336's Avatar
rbaker6336
Some have had good luck using small block chev exhaust donuts
Old Feb 9, 2009 | 11:37 AM
PaysonPSD's Avatar
PaysonPSD
Read this on FTE:
"FelPro p/n 8194 work great. They are slightly bigger than stock and squish down nicely. Use antisieze on them. Under 8 bucks a pair at NAPA."
Old Feb 9, 2009 | 11:44 AM
BENG0924's Avatar
BENG0924
Thanks for the info.
Old Feb 9, 2009 | 01:08 PM
jeff7825's Avatar
jeff7825
I remember someone on here got those from Bean's and couldn't get them to compress down enough. Don't remember who it was though.
Old Feb 10, 2009 | 09:11 AM
Kwikkordead
If it's not too late, the stock gaskets from Ford are made from a woven steel mesh, very durable and a perfect fit for the application.
Old Feb 10, 2009 | 09:28 AM
mueckster's Avatar
mueckster
The stock gaskets work well, if the up pipes aren't worn. I've seen some that were worn too bad that just the gasket wouldn't seal. Best bet, when using the stock gaskets, is to replace the pipes also. I have the OEM style up pipes and gaskets. The "bellowed ones" weren't available when I did mine.
Old Feb 10, 2009 | 12:43 PM
BENG0924's Avatar
BENG0924
I havent done it yet. Which way do you guys think is better. (not Intl pipes)
Old Feb 10, 2009 | 02:57 PM
duck fan's Avatar
duck fan
Because racetruck
I am getting up the courage to tackle this one myself. Cost always being a factor, I plan to go with the stock gaskets. If I am wrong then I am only out a little bit. If you need it the Ford part # is F4TZ-6K854-C. They should run you about $10 +/-
Welk49
May 12, 2008 03:17 PM
Beaned
Aerostar
Sep 3, 2007 03:26 AM
Beaned
Aerostar
Jun 28, 2007 09:07 PM
96powerstroke
Jun 9, 2006 08:07 PM
Beaned
Aerostar
Aug 25, 2004 08:26 PM
