Axle id
Old Feb 10, 2009 | 08:52 AM
hansen's Avatar
hansen
Axle id
Can someone tell me what size axle this is? The vin# tag says axle-24j
front diff-446cf what i could see
Old Feb 10, 2009 | 01:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
24J: 24 = Dana 60 Rear Axle / 4.10-1 / non Limited Slip // J = Power Steering
Ford didn't always list the front axle code.
Dana 44/60: The Ford axle ID tag is (was) under one of the bolts that holds the inspection cover on.
Dana 60: The Dana ID tag is bolted (2) to the housing to the right (left on rear axles) of the inspection cover.
The tag is 2" x 1/2" long and will have a 7 or 8 digit ID number, like these two examples: 603010-1 or 603010-11
Old Oct 18, 2009 | 05:04 PM
scottbral's Avatar
scottbral
Thanks Numberdummy... I thought front and rear ratios would have to be the same on a 4x4, no?
Old Oct 18, 2009 | 05:50 PM
4x4 Bart's Avatar
4x4 Bart
Front and rear ratios are almost always different. A tad bit faster in the front for more control on steering and to lessen drive train bind.
Old Oct 19, 2009 | 05:25 AM
NumberDummy
Since the rear axle ratio is 4.10-1, the front axle ratio most likely will be 4.09-1.
However...it was possible to get a 4.10-1 in the rear, a 4.56-1 in the front. This combo is rare, but it does exist.
Old Oct 19, 2009 | 02:09 PM
Henrys son's Avatar
Henrys son
really ,thats interesting.Doesnt it wind up the t case????
revans9295
Apr 26, 2012 10:40 PM
mcalvin85
Feb 21, 2005 07:36 PM
killerklown
1978 - 1996 Big Bronco
May 18, 2004 09:36 PM
greg32
Aug 22, 2003 09:14 AM
mpalamaras
May 27, 2003 05:38 PM
