Drivers side bright not working
Old Feb 9, 2009 | 06:34 PM
02X72's Avatar
02X72
On my 2002 7.3 excursion the drivers side brights will not work. The low beams come on, but no brights. Passenger side is fine. Checked the fuses, all is fine. What could it be?
Old Feb 9, 2009 | 06:47 PM
Franklin2's Avatar
Franklin2
Swap the bulbs and see if the problem moves.
Old Feb 9, 2009 | 07:34 PM
02X72's Avatar
02X72
I did just replace the bulbs a few days ago. I bet thats it. Would it be a defective bulb if the brights work and lows dont? Its the same bulb.
Old Feb 9, 2009 | 10:13 PM
Franklin2's Avatar
Franklin2
I would lean toward the bulb being bad, but it could be a few other things. If I remember correcty, the have one fuse for each lowbeam, but only one fuse for both highbeams. So if one highbeam works, the other one should too unless you have a socket or wiring problem.
evoblade
Escape & Escape Hybrid
Sep 17, 2014 12:04 PM
mdbbrown
Dec 28, 2012 01:26 PM
Einstein500
2004 - 2008 F150
Dec 9, 2012 10:58 AM
97 HD
16
Jan 7, 2008 12:34 PM
snagmaster86
Sep 13, 2006 07:28 AM
