speakers!!
Old Feb 9, 2009 | 04:59 PM
1st4x4 beach truck's Avatar
1st4x4 beach truck
speakers!!
ok i just bought a 88 ranger and i dident see how small the speaker were till i went to put some 51/4 in the dash and it dident fit. is there a way i can make it fit because have spent alot of money on these speakers and i would love to put them in the truck..
Old Feb 10, 2009 | 11:20 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Put them in the doors instead. I believe the holes in the dash are for 3 inch speakers. Mine has holes in the doors for 5 1/4 speakers, but no speakers. No stereo either. Since it currently doesn't run, I am in no hurry to put a stereo in it so someone can steal it.
Old Feb 11, 2009 | 08:52 AM
havokprime's Avatar
havokprime
You may run into a problem with them in the doors tho. You need shallow speakers for the doors or it will stop your window from rolling all the way down. My friend did that in his Civic. Put to deep of speakers in, and when he went to roll his window down, he forgot about them, and "chop!". Cut the wires.
Old Feb 11, 2009 | 05:16 PM
Nighteyez's Avatar
Nighteyez
A Civic and Ranger are two different vehicles. The wires for my door speakers come in from the front of the door. No way the window rolling down will cut them. I don't even think the window rolls down far enough to contact the speaker, but I will have to check that the next time I am out at the truck.
Old Feb 11, 2009 | 05:22 PM
nflfreak43's Avatar
nflfreak43
this shows how american engineering is far superior as far as when it comes to common sense................................
Old Feb 11, 2009 | 05:49 PM
1st4x4 beach truck
thanks for the info i havent yet cut my wholes, but i have very good comp speakers and are very good. i really hope that i can use these i will take a look tomrrow..
Old Feb 11, 2009 | 08:05 PM
havokprime's Avatar
havokprime
the window does go down far enough. ive already looked. and from what i remember at looking at the specs, the speaker depth that you would be safe with is 2 1/4 inches
Old Feb 11, 2009 | 08:09 PM
1st4x4 beach truck
wow that stinks i have speakers that are like 3 14 deep i hope i can get these to wokr some how..
Old Feb 11, 2009 | 09:21 PM
pc09123's Avatar
pc09123
You can always create spacers for the speakers. I used to do this in econo vans and such when space was an issue. Get some 3/4" balsa wood and carve out an extension ring to fit where the speaker goes. It should fit but make sure it doesn't cause interferance with your feet or legs.
Old Feb 11, 2009 | 09:22 PM
havokprime's Avatar
havokprime
i would doubt it.
the doors are shallow as it is, so its a high possibility that it wont work.
what kind of speakers are you looking to install?
Old Feb 11, 2009 | 09:23 PM
havokprime's Avatar
havokprime
thats also if he doesnt mind having it be wider than the door panel
Old Feb 11, 2009 | 10:03 PM
Nighteyez's Avatar
Nighteyez
Don't forget the window cranks either. If you use spacers to get the speakers to fit, they may interfere with the window cranks.
Old Feb 11, 2009 | 10:34 PM
havokprime's Avatar
havokprime
power window swap ftw.
Old Feb 12, 2009 | 08:13 AM
1st4x4 beach truck
i am looking to install pioneer rev speaker 300 watt max each i need to find a place for the cross overs and the amp the door speaker are just mids and lows and the i have 1 inch tweaters there made of cavlar and there liquid cooled, veryy good spaker sounds amazing would love to get them to work guess im goin to have to alot more work then a i wanted to.
Old Feb 12, 2009 | 08:21 AM
havokprime's Avatar
havokprime
well, they probably are the right size, just not the right depth. if you find a way to do it, let me know. I have some speakers that I wanted to install but are to deep
