Sponsored by: Real Truck
New project for spare
Old Feb 22, 2009 | 06:18 PM
senix's Avatar
senix
looks like it would connect to a lock
Old Feb 22, 2009 | 06:25 PM
spinella's Avatar
spinella
is that cage all thats holding the spare? or is the factory cable still being used to hoist the tire up?
Old Feb 22, 2009 | 07:38 PM
high ho silver's Avatar
high ho silver
Originally Posted by Steve_250
Nicely done!!
What does the other end (rear section on the ground) attach to?
The metal tab lines up with the receiver section of the hitch where a bolt holds it in place.
Old Feb 22, 2009 | 07:42 PM
high ho silver
Yes the cable is still hooked up but it can be used without the cable. The rear legs of the carrier keep the tire from sliding forward while the hitch brackets keep it lined up from side to side. The rear of the tire is actually resting on the backside of the hitch. Its a pretty snug fit. But I feel better knowing it aint going anywhere if the cable breaks.
Old Feb 22, 2009 | 08:44 PM
spinella's Avatar
spinella
looks good. any problems with the tire touching the exhaust. i also run 35's and a full size spare (35")would be good.
Old Feb 22, 2009 | 09:02 PM
BobbyDiesel71's Avatar
BobbyDiesel71
please post some more pics, from underneath
Old Feb 23, 2009 | 04:19 PM
high ho silver
No problem with exhaust. There is a factory bracket hanging down to prevent the tire from coming into contact with the exhaust pipe and I left if attached.
Old Feb 23, 2009 | 04:53 PM
high ho silver
Here is how it attaches to the hitch.
Gap between tire and exhaust
Tire against back of hitch
Tire at driver side hitch brace
Driver side attach point
Passenger side attach point
Old Feb 23, 2009 | 08:03 PM
powerstroke72's Avatar
powerstroke72
Very nicely done!
Old Feb 23, 2009 | 09:50 PM
spence13e's Avatar
spence13e
wish i had the materials to do something like that for that is nice!
Old Feb 24, 2009 | 08:03 PM
high ho silver
Thanks. I have to admit, I am a scrap metal junky. I'll hoard any metal someone else throws away for something like this. Made the tire carrier out of someones old trampoline frame legs. It was the right size and just thick enough to be sturdy. Oh and the pieces of chain.....extra that I cut off of my beer lounging hammock.
Old Mar 19, 2009 | 08:51 PM
crazyF250's Avatar
crazyF250
When I got my 2006 SD my spare tire cable was broke look like the cable stretched or was cut not sure. I got another off ebay cheap and welded a nut where the key deal is as I do not have that and welded a 1/2" socket on the end of the winch handle. Now its nice and solid. Also if you look on the bracket that the winch assemble is bolted to there is small hole about 3/16". I drilled that out and dropped a bolt down through it and welded it so it doesnt turn and it lines up with lug hole and stuck a nut on it and drilled a small hole for a pin like used for hood pins just in case the nut came loose. Just some added comfort as I wondered if the cable would ever break.
Old Mar 19, 2009 | 09:55 PM
  #28
Dually TAS's Avatar
Dually TAS
Wish I would have thought of that when I had my last truck! I drove around most of the time without a spare. How hard is it to mount the tire with that system?
Old Mar 19, 2009 | 10:12 PM
  #29
DAVE67FD's Avatar
DAVE67FD
How about replacing the hex bolt head with a wing nut bolt or even make a key. Cut off the end of an old box end wrench and weld to a large wing nut head then you will have a specific key without having to pull out your ratchet.
pawpaw
1983 - 2012 Ranger & B-Series
76
Jul 6, 2023 02:05 PM
The Tiger
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 22, 2016 10:19 PM
USCG_PA
Feb 23, 2016 05:12 AM
speakerfritz
Sep 6, 2014 10:53 AM
pbgsho2
May 8, 2010 07:17 PM
