performance mods ?
Old Feb 8, 2009 | 08:19 AM
crazycobra1969's Avatar
crazycobra1969
performance mods ?
Hey I have a question ? I have a 95 f-250 with a 5.8 liter this is my first truck, is there anything I can do to up the horsepower or make it perform a little better with a budget. Right now it wont go over 75 mph and i dont know why. any ideas of would be nice
Old Feb 8, 2009 | 08:24 AM
FourWheel's Avatar
FourWheel
I would start by just doing a full tuneup and go through every thing next for me would probably be exhaust but i would start with pulling the codes if it wont go over 75 can you explain whats going on a lil better?
Old Feb 8, 2009 | 10:09 AM
Lone Wolf #2's Avatar
Lone Wolf #2
Is It just not pulling past 75 or is it cutting out? What size wheels and tires are on it, did the p.o. change the rear gearing. It could be running up against the speed limiter.
Old Feb 8, 2009 | 10:49 AM
rambuck's Avatar
rambuck
First off man, congrats! I have a 92 F250 with a 351W. It is awesome. You'll love yours no doubt.
Basically yeah, full tuneup is great for any truck. Oils, cleaners, filters, and whatnot.
Some good upgrades after that would be an intake upgrade, whether it be a full K&N upgrade or whatever brand. Personally, I would go with S&B for value, and it is equal performance. Another upgrade, if you have a bit more money would be exhaust. Look around for what you like. Sometimes you'll have to make your own around a muffler. Another would be just an audio upgrade. It can be heavily used, and that's what you want. Stuff that is useful all the time.
Old Feb 8, 2009 | 01:08 PM
crazycobra1969
I did a full tune up and cut the exhaust right after the o2 senser and ran 2 3/4 in pipe with glass packs the stock muffler was way too quiet
Old Feb 8, 2009 | 01:14 PM
rambuck's Avatar
rambuck
So how is sounding now?
Old Feb 8, 2009 | 06:39 PM
FourWheel's Avatar
FourWheel
have you put a fuel filter in it could be your speed problenm
Old Feb 8, 2009 | 08:34 PM
crazycobra1969
It has a very nice rumble and rap, yes i changed the filter and both tanks and sending units and pumps and a fuel pressure regulator.
Old Feb 8, 2009 | 10:00 PM
JRS2's Avatar
JRS2
There seems to be more info needed. Lets say you mash it from a dead stop. Does it accelerate good thru first gear, hit 2nd hard ? Then what happens in 3rd, 4th ? What seems normal and what doesn't when pushing it like this ?
Old Feb 9, 2009 | 08:01 AM
crazycobra1969
it does fine from a dead stop just on the highway at about 75 the rpms wont go any higher and the pedals to the floor i ran a scaner on it and it brought up a TPS and o2 senser code would that have anything to do with it?
Old Feb 9, 2009 | 08:10 AM
MaTchDogg's Avatar
MaTchDogg
How many miles on engine? for the O2 sensor check wiring, and do a voltage drop before and after the O2 sensor u should have bout source Voltage before and less than .5Volt after. For the TPS at idle slowly depress ur throttle pedle, if u feel a slight studder or its bout to stall then check ur wires. let me know what you get.
Old Feb 9, 2009 | 08:12 AM
Dean88's Avatar
Dean88
Hmm, does it feel like its governing out?? One of my buddies had a F-150 that would just stop at 75, and it turned out that it had some kind of safetychip in it for the po's kids.
I would go ahead and put a new 02 sensor in it bein is it will def help out mileage if its out. I dunno about the TPS, I've never had to deal with one. The only thing I would try is disconnecting it and seein what it did.
Old Feb 9, 2009 | 08:50 AM
crazycobra1969
its got 152,000, also the tranny starts to shift very hard into 1st and and 2nd 3rd not as hard and it doesnt want to accerate but i unhook the battery for a while and it doesnt do it any more so its some senser i think
lew52's Avatar
lew52
I had the tps go bad on mine but it made it not have any power at half throtle... Fine at WOT..... There could be a speed limiter on it... Not sure when it would kick in .... Theres a rev limmiter on it to ... One the 302s its set at 4700 RPM...You have to get in the computer to get them out...
Old Feb 9, 2009 | 09:07 AM
RJG1987's Avatar
RJG1987
i can very well peg my speedo and go past the 90mph it says, i'd say i can hit 104 or so, i don't do that much anymore with the 162,xxx on it, i installed a tach and it runs outta breath around 5250 or so....thats my 96 302 5 speed, one of my 300's had trouble around 75 with the heat on? good thread also f-250's have beefier suspension and a bigger rear in the back for 2wd
