performance mods ?
Old Feb 9, 2009 | 09:16 AM
MaTchDogg's Avatar
MaTchDogg
check to see if u got a gov' if so remove it and see what u got if not, get a wiring diagram of ur TPS voltage drop all 3 wires, the pwr wire should show source Voltage mite be bout 5volts, signal wire should show Voltage based on position of throttle, closed throttle should have low voltage close to 1volt, WOT should have almost source, ur gonna need to slowly work ur way to WOT if u see a the Volt meter ready OFL, OL or jumps back to zero the sensor is bad, if not u got a wiring issue. also your ground should be less than .5 Volts. dont worry bout the trans. till u got one of these fixed, it mite be ur problem for the trans.
