Sponsored by: Real Truck
In Cab Brake Controller
Old Feb 8, 2009 | 07:56 AM
WK57ABF's Avatar
WK57ABF
Hi folks,
Have just found this forum and registered. We purchased a 2008 F350 in May 2007.
Our truck shows "Trailer Brake Module Fault" on the dash display when starting the engine. Is this a fault or a warning? Also what does Job #1, 2 or 3 build mean - ours is Job #1 build. Are there any recalls for this early 08 truck.
Thanks for any help, John
Old Feb 8, 2009 | 09:03 AM
senix's Avatar
senix
that means that you need to take it in under warrenty and have them look at the TBC system. Most likely there is something wrong with the circuitry and it will have to be replaced.
They will not have it in stock so they will have to order it but you can drive the truck till the part comes in.
Job 1, 2 or 3 refers to when the truck came off the ***. line. Job 1 is the first batch for the model year and then 2 is like a few months later and then maybe job3 if needed in the spring run.
This is common, it is due to slight changes during the production run to enhance the build or a small design change.
So depending on when your truck is manufactured that is what job you have, look at the door jam and let us know the date of man. and then will can tell you the job #
Old Feb 8, 2009 | 10:07 AM
WK57ABF's Avatar
WK57ABF
senix,
Thanks for reply.
Having problems finding a dealer in UK who will carry out diagnostics. All UK Ford dealers have the equipment but they are reluctant to work on imported trucks. Nine times out of ten wont work on them at all. However still searching for someone to do diagnostic check.
The US dealer wants the fault codes before he will replace TBC under warranty.
Date of manufacture of truck taken from door jam is 03/07.
John
Old Feb 8, 2009 | 03:36 PM
caprang's Avatar
caprang
Welcome to FTE!!!
If you check out the tech folder at the top of the 6.4 forum you will see some information regarding job# and some of the other hot topics discussed. The most recent items to be released concern a venturi tee installed for the radiator as well as a reflash of the trucks computer system to improve some driveability concerns and update the message center.
I have never seen the warning message you are getting so I believe this is something you will have to find a dealer to diagnose. Have you tried a different trailer just to be sure you dont have a bad ground (or something like that) on your trailer.
Old Feb 8, 2009 | 03:37 PM
caprang's Avatar
caprang
Found this in another thread. Maybe it will help.
The dreaded "WIRING FAULT ON TRAILER" on the IC and the annoying BEEP came back.
I have a job #1 6.4 PSD that had this message in July 2007. Ford replaced the wiring assemble WPT 401 and the 7C3Z 14489 AA connector as outlined In the Special Service Message 19852. The Special Service Message also stated the Ford Engineering is currently investigating the problem and to monitor Oasis for an update.
Today, I has the truck back in the dealership with the same message fault and the beep. The dealership repaired the wiring harness with the same fix and parts that were used in 2007. We couldn't find any update on Oasis to indicate Ford Engineering has found a solution since July 2007.
My fear now is the trailer wiring message and the beep will return after my warranty is finished.
Does anyone have an update on this common message fault so the message fault can be fixed and not return as I fear this repair is only till the next time but with my wallet instead of the 3 year warranty?
Old Feb 8, 2009 | 05:42 PM
LJC's Avatar
LJC
Like I indicated in the other message. I had this issue. Ford replaced the sensor ant that was it.
LJC.
Old Feb 8, 2009 | 07:42 PM
Larry NCKS's Avatar
Larry NCKS
Originally Posted by WK57ABF
Hi folks,
My official build date is 03/19/07. This a job 1 build. I've never seen the error message you describe so can't help you there. Things that I know happened in later builds were deeper front air dam, higher speed axle ratio (3.55) and tire pressure monitor. I'm sure there are more. I've had four things done to my job 1 under recall or customer satisfaction programs. These are, replacement headlamp for internal fogging, seat back recall, venturi T in cooling sytstem (08B06) and software flash (08B07).
If yours hasn't had the latter two, I'd make sure it gets them soon. These customer satisfaction programs have expiration dates which I think are at the end of the calendar year.
Old Feb 9, 2009 | 06:53 AM
WK57ABF's Avatar
WK57ABF
Thanks all for info, we've only been two days on this forum and the help has been invaluable.
caprang
The nearest dealer that can perform diagnostics and reflash is near an American Air Force base at Mildenhall, Norfolk - 380 miles from us. Phoned them this morning and they can also do the recalls. Yes, we also get "Wiring Fault on Trailer" and "Trailer Disconnected" but these messages cancel when we plug in trailer.
LJC
Which sensor did Ford replace?
LarryNCKS
The dealer mentioned above can do 08B06 and 08B07. I will get these done as soon as I can. Does 08B06 involve a new part?
Regards, John
Old Feb 9, 2009 | 07:14 AM
Larry NCKS's Avatar
Larry NCKS
08b06
yes 08B06 is a tee with a venturi placed in a coolant hose. It's supposed to stop rapid return of coolant through the degas bottle I think. Maybe someone knows more specifics on this.
Old Feb 9, 2009 | 07:15 AM
senix's Avatar
senix
The 08B06 and 08B07 are reflashes for the PCM/TCM. 08B06 is for Manual trans and the 07 is for the auto trans.
Changes the message display when you go into regen and improves shift points for the auto trans.
Old Feb 9, 2009 | 07:38 AM
Larry NCKS's Avatar
Larry NCKS
[quote=senix;7118222]The 08B06 and 08B07 are reflashes for the PCM/TCM. 08B06 is for Manual trans and the 07 is for the auto trans.
/quote]
You had me concerned Senix. I thought I'd gone bonkers. I went back and checked and it's not me. 08B06 is the venturi T customer satisfaction program. 08B07 is the reflash that changes regen message and does some other things to PCM & TCM.
Old Feb 9, 2009 | 07:55 AM
WK57ABF's Avatar
WK57ABF
Thanks folks - got it!!
John
Old Feb 9, 2009 | 07:58 AM
senix's Avatar
senix
Ask Your Ford Truck Question
Type your question here
letters left
TSB Lookup : FORD : 2008 : F-250 SDTSB data for: 2008 FORD F-250 SD
Bulletin Number: SSI-08-T-01
Sequence Number: 10026381
Date: 20080701
Component Name: 061200 ENGINE AND ENGINE COOLING:ENGINEIESEL
Make: FORD
Model: F-250 SD
Year: 2008
Summary:
FORD SUPER DUTY: DEMONSTRATION/DELIVERY HOLD S008 F SUPER DUTY VEHICLES; 6/4L DIESEL ENGINE COOLING SYSTEM VENTURI TEE INSTALLATION UPGRADE. AFFECTED VEHICLES, THE RADIATOR MAY DEVELOP CRACKS FROM A REVERSE FLOW OF COO AIR/COOLANT FROM THE
This is the venturi T.
Old Feb 9, 2009 | 08:35 AM
caprang's Avatar
caprang
I dont mean to turn this in to he said/she said, just trying to make sure we have the right info. The letter I received in the mail says 08B06 is the Venturi Tee Kit and expires 6/30/09.
Senix, I think what you are referring to is the original letter (July 2008) to the dealers that only included vehicles still in inventory. Ford later (oct/nov 2008) opened this up to include all sold vehicles as well.
WK57ABF, in the tech folder is a complete write up about the venturi tee. At the time Ford wasnt offering this as a customer satisfaction program and a lot of us were doing it ourselves. But it will show you what the dealer will be doing when you take it in.
Old Feb 9, 2009 | 09:42 AM
senix's Avatar
senix
caprang,
I think you are right.
