Leveling Kit 2.5 3" recommendations
Old Feb 7, 2009 | 09:15 PM
blakeusa's Avatar
blakeusa
OK Im back because I need to get my truck blinged out...
Want to buy a leveling kit and have seen several options including some on ebay.
What should I buy.
Old Feb 7, 2009 | 09:40 PM
fxstbchopper's Avatar
fxstbchopper
I went with a 2.5" shackle leveling kit off ebay and I am very happy with it the truck sits just right and the they only cost me 45 bucks.
Old Feb 7, 2009 | 09:58 PM
Mid_Mo_F100's Avatar
Mid_Mo_F100
I went with the Summit 2 1/2 kit (spring pack style) because it had the long leafs and I wanted to add some arch back to my sagging front springs, which it did. I am pleased with its quality.
Old Feb 7, 2009 | 10:56 PM
mud dawg 89's Avatar
mud dawg 89
eBay Motors: Ford F-250/F-350 99-04 Super Duty 2" Leveling Lift Kit (item 260354926586 end time Mar-01-09 15:06:34 PST)
is something like this any good? im new to ford...
Old Feb 8, 2009 | 01:21 AM
camodown's Avatar
camodown
I have a performance sales 2.7" mini sping pack and so far it's worked fine. A lot of people suggest an adjustable track bar so the axle stays centered under the truck but I didn't need one. If you get a mini pack, stay away from ones that have their packs welded. Use red lock tite on the bolts too!
Old Feb 8, 2009 | 01:37 AM
mongo75's Avatar
mongo75
I myself was considering going the shackle lift route, but with 215k on my truck, my front ens springs could use some helper springs.
Old Feb 8, 2009 | 12:28 PM
blakeusa's Avatar
blakeusa
Perfromance Sales-- this is a good kit- who else sells this thanks
eBay Motors: 99-04 Ford F250 F350 Leveling Lift Kit Super Duty 2.7" (item 260301925405 end time Feb-14-09 10:45:58 PST)
Old Feb 8, 2009 | 03:46 PM
Adam0331's Avatar
Adam0331
I got a rancho spring kit that brought it up and looks good. I'm not sure about that kit there.
Old Feb 9, 2009 | 09:37 AM
superduty4x4's Avatar
superduty4x4
I bought a new ProComp 2" kit from a guy that never got around to installing it for $100. I like this option better than the Ebay shackle only kits as it comes with front hangers also. Look around, there are deals to be found.
Old Feb 9, 2009 | 06:20 PM
robs01f250's Avatar
robs01f250
there are two different styles of leveling kits on this thread in posts 4 and 7 can anyone help me out on which one is the best bang for my buck. any help is appreciated
Old Feb 9, 2009 | 06:34 PM
superduty4x4
#4 is a mini spring pack, #7 is an add-a-leaf. #4 will maintain stock ride quality, #7 will probably make it stiffer. Bang for the buck? I'd say it's a draw.
Old Feb 9, 2009 | 06:38 PM
monsterbaby's Avatar
monsterbaby
actually thats backwards, #4 is an add-a-leaf, and 7 is a mini spring pack
Old Feb 9, 2009 | 06:47 PM
superduty4x4
Bah, I forgot I opened them backwards :
Old Feb 9, 2009 | 07:26 PM
sideshow's Avatar
sideshow
Originally Posted by blakeusa
I bought this kit a while back, and it isn't 2.7". The spring pack is EXACTLY 2" (4 1/2 inch plates) so I fail how to see where the says it will provide 2.7" of lift. However, it did provide exactly 2" to my truck and i have 35" with no rubbing (ok, some rubbing if at full lock and driving over a bump). Ride quality remained the same, and shocks were reused. I do want to put new shocks all around though. EASY install as well. Given the cheapness (cost) i figured i'd try it out, and if I decided later to go bigger, it wouldn't set me back too much.
Old Feb 10, 2009 | 01:13 PM
jacksonford's Avatar
jacksonford
i got my kit direct from rough country, its a 2.5 but its actual lift was3.25 on the front. i also got the add a leasf for the back and it seems alright so far.the lift rides stiffer than stock,but thats what i wanted out of it. the price wasn't bad and it all bolts on with a little time
