ford part number help.
Old Feb 7, 2009 | 07:11 PM
gingerbreadmaniac's Avatar
gingerbreadmaniac
Its off a ring gear the part number is c9az-6384c
my questiuon is what application (vehicle engine trans combo etc.) was this off of so my parts store can look it up.
-gbm-
Old Feb 7, 2009 | 11:32 PM
dlburch's Avatar
dlburch
IF you can believe what you read on the Internet:
C9AZ-6384-C Make Ford Application Ford Passenger Year 69-70 OD 15.52 ID 14.513 Width 0.5 ENGINE SIZE V8 429 TEETH 176 PITCH 12 CHAMFER NONE
Old Feb 8, 2009 | 11:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
my questiuon is what application (vehicle engine trans combo etc.) was this off of so my parts store can look it up.-gbm-
There is no such thing as a Ford part number of C9AZ-6384-C.
If the number is stamped on the ring gear, that's an ID number, not a part number, and the number would be C9AE-6384-C =
Ford part number: C9AZ-6384-A .. Flywheel Ring Gear-176 teeth.
Fits: 1969/70 429 with a Ford 4 speed.
If you are looking for a ring gear for a 460 with a manual transmission, this one will not be correct.
Old Feb 8, 2009 | 04:52 PM
gingerbreadmaniac
I will explain later but could you also identify what number this may be. I have a NOVA 1 1/16 10 spline 12 inch clutch in my hand and the number on it reads. 27753 4906 can you tell me what application this is for (vehicle, year, motor trans combo etc and what pressure plate would go with it.
thank you
-gbm-
Old Feb 8, 2009 | 05:03 PM
NumberDummy
I will explain later but could you also identify what number this may be. I have a NOVA 1 1/16 10 spline 12 inch clutch in my hand and the number on it reads. 27753 4906 can you tell me what application this is for (vehicle, year, motor trans combo etc and what pressure plate would go with it. thank you -gbm-
I haven't a clue what that is.
I can ID Ford part numbers, but nothing from the aftermarket sector.
Old Feb 8, 2009 | 05:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
A nova is a chevy isn't it???
Old Feb 8, 2009 | 05:14 PM
NumberDummy
Cannot ID those parts either.
There are several Nova versions and years, the first one was a model of the Chevy II in the early 1960's.
Only numbers I can decipher are FoMoCo.....Studebaker & Packard and a smattering from Hudson.
Old Feb 8, 2009 | 05:23 PM
gingerbreadmaniac
this is not a nova as in a nova car its a clutch manufacturer named nova.
-gbm-
Old Feb 8, 2009 | 05:31 PM
NumberDummy
Dunno what you are trying to do, but...if you have a 429 M/T flywheel, it takes a 10 spline 11 1/2" clutch on a 12 7/8" bolt circle.
Old Feb 8, 2009 | 06:26 PM
Jermafenser's Avatar
Jermafenser
*shakes head*
Binkowski
16
Mar 3, 2017 05:04 PM
SVTDriver97
16
Jun 27, 2014 08:56 PM
sgt.bigjim
Nov 20, 2013 09:36 AM
beeser
Oct 3, 2013 04:33 PM
