Bed Rail Part Number
Old Mar 7, 2014 | 09:12 PM
Binkowski's Avatar
Binkowski
Hi,
I bought some bed rails off of e-Bay. They match up with the holes in my bed of my '72 F100 perfectly. Curious to know if the part number matches with this era.
The part number of the cross bar is C9TJ-9932222A. It's stamped FoMoCo. The part number on the two middle supports and the two bases is just a variation so I know they are all the same.
I tried looking at a generic part number description and the C9TJ would seem to indicate that it was for a 1969 Truck but that is as far as I got. Curious.
Either way I am pleased as they will fit nice and look nice on the truck.
Old Mar 9, 2014 | 05:43 PM
Binkowski's Avatar
Binkowski
installed
Well I got the Bed Rails installed. Took longer to find the correct size stainless steel pan head bolts than to put them on. All the holes matched up exactly right. I'll have to keep my eye out for the correct plastic gaskets that should be under it, or try to make my own.
Still curious if I am reading the part number correctly and these are from '69. I uploaded a photo to my garage so I'll see if I can link it. I like the look and for $75 it can't be beat.
Old Mar 9, 2014 | 07:15 PM
GLR's Avatar
GLR
The same part/engineering number might be used for many years. For example: I've seen C5-- on power window motors for a 91. (1965-91)
Old Mar 10, 2014 | 05:18 PM
JEFFFAFA's Avatar
JEFFFAFA
Yes. Bump body style.
C= 1960's decade
9= the year in the decade
T=Mostly used for "F" series trucks but I've seen it on more. Sometimes used universally for "trucks". Later the little Rangers used it also.
J=wierd letter designation because the part is an "accessory" part. This digit normally shows who's responsible for the part. I.E engine,electrical,body,etc.
Old Mar 10, 2014 | 06:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Both the 6 1/2' and 8' bed rails are basically the same thru 1991.
I've listed both the following part numbers multiple times after FTE member Phil105 asked me to find him a 6 1/2' kit.
Phil bought one of these kits, installed it on his 1970 F100 Ranger XLT, it fit perfectly. There are pics of his truck with the rails installed in his garage.
I haven't looked recently, but there may be a few of both of these kits available NOS
E7TZ-99322B30-A .. 8' Bed Rail Kit / Obsolete
E7TZ-99322B30-B .. 6 1/2' Bed Rail Kit / Obsolete
Left (upper): 1969/72 / Right (lower): 1980/89.
Old Mar 10, 2014 | 08:25 PM
Binkowski's Avatar
Binkowski
Thanks for the information guys. Appreciate learning more.
I love the look of the wooden ranch/farmer sides.
Alex
Old Oct 19, 2014 | 05:50 PM
benbuilder's Avatar
benbuilder
Bed rails
Number Dummy or anyone else. I have two of the three pieces of a bed rail kit for each side. I need two of part number c9tj9932240. I have c9tj9932222 and 2241. Do you know where I could find them, or will I just need to keep checking ebay? Thanks
Old Oct 20, 2014 | 07:13 PM
JEFFFAFA's Avatar
JEFFFAFA
The part number was C9TZ9932240A.
Mcdonald Obsolete has 1.....in IN.......812-359-4965.
Dennis Carpenter FORD has 2....(ding,ding,ding)...in NC..704-786-8139.
"That's all Folks"
Old Oct 20, 2014 | 07:48 PM
benbuilder's Avatar
benbuilder
Jeffata,
Thanks for the info. I will make some calls tomorrow.
Old Oct 21, 2014 | 11:29 AM
NumberDummy
I need two of ID engineering number C9TJ-9932240. I have C9TJ-9932222 and 2241.
Be aware of what you're asking for:
C9TZ-9932240-A .. Rail End Support: Right Hand Rear & Left Hand Front
C9TZ-9932241-A .. Rail End Support: Right Hand Front & Left Hand Rear
Old Oct 21, 2014 | 11:39 AM
benbuilder's Avatar
benbuilder
Thank you, I have since learned that I had the ENGINEERING number. I have begun my search.
Old Mar 3, 2017 | 01:21 PM
benbuilder's Avatar
benbuilder
So, if i need the gasket which goes under the center support, the square one, would it be C9TZ-9932244?
I have the 73-79 parts book not the 68-72. I have one of the gaskets and it is labeled C9TJ-9962244-A
Old Mar 3, 2017 | 01:42 PM
JEFFFAFA's Avatar
JEFFFAFA
The part number was C9TZ9932244A. And you're in luck. Only one place has them but they do have 2.
Premium Listings
NOS Parts Ltd.
Recently Updated
Part Number:C9TZ9932244A
Seller:NOS Parts Ltd.
Description:PAD-BODY SIDE PICKUP BOX TOP RAIL
Phone (972) 937-2201
Price:Request PricingEmail:Send Seller Email Inquiry
Quantity:2
Old Mar 3, 2017 | 04:13 PM
benbuilder's Avatar
benbuilder
thank you. bought it
Old Mar 3, 2017 | 04:14 PM
benbuilder's Avatar
benbuilder
Bought it. now I have a complete set for a short bed. Thanks
