Factory Subwoofer
Old Feb 22, 2009 | 04:36 PM
BrianB31's Avatar
BrianB31
Ok, my '05 fx4 supercrew is an oddball. I pulled off the radio trim ring and I have the 4 pin connection up in my dash connected to a dummy plug. I then went back to the rear seat, found the slit stuck my fingers in there and no wire. I then pulled up the rear scuff and there is no take off running under the carpet going inboard, so I partially removed the c pillar trim and the only connections are the two inlines for the headliner harness.
Is there anywhere else the rear plug could be? I have a nagging feeling that my truck's i/p harness has the connection and my body harness does not because of plant/wiring complexity.
It's still too cold up here to start taking this thing apart, but I plan to look at the i/p to body harness inline connection and see if the sub connection stops there when it gets warmer.
Originally Posted by BluByu1986
I've got a '05 FX4 and the plug for the sub was in my truck. You just have to feel around in that slit in the back seat. The plug that's in the dash is taped up and you can't miss it when you pull the factory deck out.
Good luck,
Old Feb 22, 2009 | 04:40 PM
SteveVFX4's Avatar
SteveVFX4
Like I said on page 1, my FX4 did not have the rear plug either. That other guy got lucky. Mostly Lariat owners post back here that they found the plug. But not so many FX4 owners...
Old Feb 22, 2009 | 05:04 PM
BrianB31's Avatar
BrianB31
Rats I wanted to add the sub. I had to build a harness when I put a 2005 Escape mach radio and sub in my Ranger. I can do it again, just have to wait till it's warmer.
Old Feb 22, 2009 | 05:30 PM
Catmonkey's Avatar
Catmonkey
Well I removed the rear seat and the pillar moldings and the sill guards and this Lariat does not have a subwoofer plug. The extra connector is in the dash, so there must be a connecting harness that terminates the subwoofer plug. I knew this was too good to be true.
Is there a sub box that is of similar size to the factory box? I guess I'll have to run a sub the conventional way.
Old Mar 9, 2009 | 11:55 AM
SteveVFX4's Avatar
SteveVFX4
For those who don't have the factory sub plug under the rear seat (like me), then I got a great solution for you.
I just sold my truck and got a new 09 truck. So here is my setup if you want it, check out the details here:
https://www.ford-trucks.com/classifi...t/26285/cat/55
trusty71
Oil & Lubrication
Oct 23, 2014 09:18 AM
snakedoc
13
Jan 26, 2014 05:06 PM
SideWinder4.9l
Jun 23, 2013 11:42 PM
Daltonsheets1995
16
May 11, 2012 03:19 PM
