to much weight
Old Feb 6, 2009 | 04:33 PM
kudo's Avatar
kudo
Question to much weight
I have a 92 f 250 and I want to put about 2496 lbs tile in the bed is that to much weight
Old Feb 6, 2009 | 06:18 PM
gottashiftgears's Avatar
gottashiftgears
this post doesn't go here.... mods move please.... but to answer the question, it should be ok for a short period of time... just don't do it every day...
Old Feb 6, 2009 | 08:12 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Look at the GVW sticker on your door. Subtract the truck's curb weight of your truck from that number and you will have your payload. That includes everything in the truck, including passengers. My '94 F250 has a GVW of 8600 pounds and it weighs 5200 pounds. This gives me a payload capacity of 3400 pounds. I'm sure your F250 will be good for that much provided the tires are good for the weight, check the load rating on your tires. Also make sure you have enough air in the tires. When I load my truck with over 2,000 pounds I increase pressure from 55 psi to 80.
Old Feb 6, 2009 | 08:19 PM
Old93junk's Avatar
Old93junk
No problem , just dont make a habit of it, And, just hope you dont have to stop fast!.
Old Feb 6, 2009 | 08:51 PM
FourWheel's Avatar
FourWheel
I have put more than that in my f150 without any major problems just take it easy and realize that there is 2496 lbs in there
Old Feb 6, 2009 | 11:19 PM
john410312's Avatar
john410312
I'm a semi driver. Extra weight increases stopping distance at the same proportion as increased speed.
Make sure the tile is spread evenly across the box. If it's on a pallet, block it so it doesn't shift forward if you have to stop quickly, or move sideways if you corner too quick.
SAFETY FIRST.
Old Feb 7, 2009 | 12:09 AM
jr32560's Avatar
jr32560
I have carried well over a ton and a half on my old f150 for short distances-it's a ford it's tough-just as the others said secure the load and increase stopping distance by a lot!
Old Feb 7, 2009 | 09:49 AM
kudo's Avatar
kudo
Thanks guys big help
Old Feb 7, 2009 | 10:52 AM
aging_F150's Avatar
aging_F150
The last time I hauled too much weight in my '87 1/2 ton I was 3/4 thru a stop light at a busy intersection with both feet begging the brakes and my better 1/2 screaming in my right ear. Luckily no contact with vehicles having the right-of-way, but still having trouble with that ear....
as another said - SAFETY first! Make sure of your stopping distance.
Old Feb 7, 2009 | 11:25 AM
rambuck's Avatar
rambuck
SAFETY FIRST.
Thank you for posting this man. Nobody ever remembers to spread out weight evenly or be more cautious and whatnot when driving. If only everybody knew...
Old Feb 7, 2009 | 11:31 AM
Old93junk's Avatar
Old93junk
SAFETY FIRST.
Very good advise!, Any truck driver can tell you, one of the worst things that can happen is to have your load shift. Same applies even in a pick up. And limit your speed and anticipate stops.
Old Feb 7, 2009 | 11:32 AM
Dean88's Avatar
Dean88
Don't worry about that load, it won't even be a workout for your truck. I haul 4,000 lbs in my bed at least once a week when I go get cake. But as everyone else has said just take it easy and look a good ways ahead for stop signs and such.
Old Feb 7, 2009 | 12:17 PM
Old93junk's Avatar
Old93junk
Come to think of it, my cab over camper weighs 2,600lbs and the 93 F250 handles it with NO problem. Like everyone said, just watch your stops.
