Floor Mats
Old Feb 6, 2009 | 11:50 AM
Redmanbob's Avatar
Redmanbob
Question Floor Mats
What year floor mats would work in a 64?
Doesn't need to be a "perfect fit" really. The truck has nothing at the moment, and with a 4spd and no shifter collar it's pretty darn ruthless in the cab. A shifter collar would help some but the other areas, (steering column, wiring, clutch arm, etc.. all let in some air/noise. Would be great to find a used floor mat and toss it in there.
Old Feb 6, 2009 | 01:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/64 F100/750.
1965 F100/250 4WD / 1965 F350/750.
1966 F250 4WD / 1966 F350/750.
Most used floor mats will be brittle, better off buying a new one.
Try autockm.com for the mat, they are located in Escondido.
By a shifter collar I assume you are refering to a rubber boot around the floor mounted gear shift lever.
A shifter (shift) collar is found on a 3 speed or A/T, what the shift lever attaches to.
Old Feb 6, 2009 | 03:33 PM
Redmanbob's Avatar
Redmanbob
Not too much info on their site so I'll email them and see what they have to say. I wondering if he molded vinyl is a roll that you use a heat gun to form yourself or ? Well find out soon. Thanks for the tip.
otonedog
May 27, 2013 08:46 AM
427mike
Jan 12, 2013 10:34 AM
emayes2000
Jun 12, 2012 12:03 PM
F-250fx4
Dec 14, 2006 12:42 PM
bullit340
Jan 2, 2006 10:58 PM
