Why are you going to vent all that stuff into the air, and then breath it when it comes into the cab?
Also, if you leave the PCV system active, and just vent the other side, the PCM will get "unmetered air" that is not passing through the MAF and will cause a lean condition.
I'd leave it alone if it's not causing any problems. It's not going to help performance at all.
