Sponsored by: Real Truck
Contrary To Conventional Wisdom
Old Feb 5, 2009 | 02:55 PM
beeser's Avatar
beeser
During the process of selling my previous truck and buying another, both the seller and I followed conventional wisdom and had our intended purchases checked out by a mechanic. The buyer of mine had a local service station do the inspection. While watching the process the thought occurred to me that it was almost a complete waste of money. The buyer could have just as easily done the work himself. All the mechanic did was check the fluids, lights (brake, turn signals, etc.), engine belt(s) wear, brake pads, and tires. Nothing was done that a reasonably informed person couldn't do themselves. Unfortunately I didn't follow my thoughts and had a Ford dealership do the inspection on my new to me '04 F250. The only difference between the two inspections is that I paid considerably more. So my question is, what purpose is served by a mechanic doing a pre-purchase inspection? Should there be more involved than what I described? I recall that such inspections used to involve a cylinder compression test and the brakes involved checking more than just pad wear.
Old Feb 5, 2009 | 03:23 PM
rmosso1's Avatar
rmosso1
When you buy a boat you get what is called a survey. Eighty Pages. I paid almost $2,000. Guys who perform the service are licensed and insured.
I had 81 page report that said "FIRST CLASS" condition. About 100 hours later, the exhaust melted down and caused substantial damage. It had happened before, and once you knew what to look for, readily identifiable.
My point: As stated on the X Files: TRUST NO ONE.
I should not have bot the boat. It was too good of a deal
Old Feb 5, 2009 | 03:28 PM
1979Mustang's Avatar
1979Mustang
When I bought my "Pre-owned certified" F-350 last fall I thought it was given a once over. I had it back to them for front brakes and too many other things to list. The truck is flawless now but you cannot trust everybody!!!
Old Feb 5, 2009 | 03:31 PM
WeWonIt's Avatar
WeWonIt
Did they put it on the diagnostics machine? I too have had the compression checked on vehices that I believed to be questionable.
Old Feb 5, 2009 | 04:18 PM
rmosso1's Avatar
rmosso1
Dumb question: Did you have a 6.4 diesel checked for compression?
Old Feb 5, 2009 | 04:50 PM
ReAX's Avatar
ReAX
If you don't know what to look for, it's best that someone who does inspect a purchase. However, if your familiar with the vehicle enough for basic overview and an eye for anything suspicious, then you might as well do it yourself.
Old Feb 5, 2009 | 05:03 PM
beeser's Avatar
beeser
Before purchasing my '04 F250 I asked plenty of questions here and received a generous amount of responses. (BTW, thanks again for the help!) Besides making sure to get Oasis and Carfax reports the only thing mentioned was having the vehicle checked by a mechanic.
Let me pose the question asked earlier slightly different. What should be included in the inspection of a used vehicle by a mechanic?
Old Feb 5, 2009 | 05:04 PM
beeser's Avatar
beeser
I don't know if this is directed to me but to answer your question, the engine in my '04 F250 is a 5.4L gas. And no to the compression test.
Edit: After thinking more about this, it seems to me that a compression check in my situation may not have been a good idea. It's my impression that once the a spark plug is removed the boot behind the coil should be replaced, which is not cheap. Does that make sense?
Old Feb 5, 2009 | 05:28 PM
Mustang6147's Avatar
Mustang6147
Not to sound ill manored or arogant. I thought, Taking a car/truck to a mechanic was more of a, well, gender thing?
I would think you might ask to use the lift in the service bay, after hours, from the dealer your buying the truck from, or at a service/ repair facility you do bussiness at.
Compression is easily checked by simply taking off the oil fill cap while the engines running. If none or a little white smoke is coming out, its ussually OK. If alot of smoke is coming out, those cylinders are shot. (ring blow by)
Old Feb 5, 2009 | 05:39 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Inspections are only as good as the mechanic/dealer doing the checking. Years ago I bought a Suburban from Carmax....with the "10 day fix anything wrong" warranty. This vehicle had just had a "150 point quality & safety inspection" completed on it, as well as Maryland state inspection (which is quite strict). Took it home and looked it over on the weekend, took it back on Monday. Forget just how many things they ended up fixing, but it included replacing turn signal switch, steering gear box, radiator, & rear brake shoes, fixing exhaust leak, and installing missing seat belt. All of which were "missed" on both inspections!
Old Feb 5, 2009 | 05:58 PM
beeser's Avatar
beeser
Originally Posted by Mustang6147
... Compression is easily checked by simply taking off the oil fill cap while the engines running. If none or a little white smoke is coming out, its ussually OK. If alot of smoke is coming out, those cylinders are shot. (ring blow by)
Never heard of this one before.
Old Feb 5, 2009 | 06:30 PM
ReAX's Avatar
ReAX
I'll try to make up a check list.
Old Feb 5, 2009 | 06:51 PM
rmosso1's Avatar
rmosso1
P. S. Do a check list on a 6.4 diesel which includes a compression test would require removal of an injector fuel line, which would require a new injector line and which probably mean the removal of the cab and a MAJOR expense, if done properly.
Like I said above: TRUST NO ONE...
Old Feb 5, 2009 | 07:16 PM
ReAX's Avatar
ReAX
Take a peek, http://sites.google.com/site/reax222...attredirects=0 I know next to nothing about diesels.
Old Feb 5, 2009 | 08:25 PM
WeWonIt's Avatar
WeWonIt
What? It may have been a while, but I seem to recall a tool that looked very simular to this one...
KD Tools Compression Tester - Model KDS2428 at Sears.com
I was looking to buy my first Camaro at 18 years old, and was not sure of the previous owners claim to have rebuilt the engine. I mentioned this because of the OPs gas engine and question of compression testing. As for a diesel, I'm pretty sure those rely on PFM.
