E-check needed?
Old Oct 18, 2000 | 09:40 PM
95xltmud's Avatar
95xltmud
E-check needed?
Old Feb 24, 2001 | 11:43 PM
eldoradojohn's Avatar
eldoradojohn
E-check needed?
I'm considering buying a 78 Bronco with headers and side pipes but no catylitic converters. Will it pass an Ohio E-check inspection? Thanks
Old Feb 25, 2001 | 08:47 AM
StrangeRanger's Avatar
StrangeRanger
E-check needed?
No, not if it originally had a cat. E-check includes a visual inspection for presence of a catalytic converter. If it has been removed, you fail regardless of actual tailpipe emissions.
Old Feb 25, 2001 | 05:54 PM
eldoradojohn
E-check needed?
I guess what I really wanted to know was if this year bronco could have come without a cat. It did not say "unleaded only" anywhere it usually does. Thanks again
Old Feb 25, 2001 | 08:57 PM
hotrodford_88's Avatar
hotrodford_88
E-check needed?
I believe after 74 anything under 3/4 ton had to have cats. Except the 74-79 F-150's. But I do not know what the broncos rating is. But I would venture to say that it originally had cats under it.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Feb 26, 2001 | 12:17 PM
1911bronco's Avatar
1911bronco
E-check needed?
78 Broncos had no cats....I don't know what your inspecters will say about the sidepipes, but I wouldn't think it should make a diference.
Old Feb 26, 2001 | 06:16 PM
RRL78's Avatar
RRL78
E-check needed?
I have a '78 bronco that did'nt come with cats. I used to have to take the bronco through emissions, and they would look under it with a mirror to see if it had cats. Every time, i told them it did'nt come with them, they would get there little book out and look up my truck and " it did'nt come with them ". Man, that used to aggreivate me. Any way good luck, i hope you buy it, i sure love mine. Fixing to put a lift under it. Have a good one. Rob
Old Feb 26, 2001 | 08:53 PM
85351ho's Avatar
85351ho
E-check needed?
yall think my f-250 came with a cat? it had a 351m in it, 4x4, dana60 rear, 44 front and a 4 spd?
1985 F-150/351Ho/4wd/6inch with 33's
1979 f-250 429/4spd/5inchwith 36 inch buckshot mudders
on a quiet night your can hear a chevy (lol,you can watch a dodge) rusting away
