Electric fan?
Old Feb 5, 2009 | 07:21 PM
Dforgy's Avatar
Dforgy
Electric fan?
Just popped in my head, anybody ever switched to an electric fan? Save engine load and engine bay space, and a small amount of weight. Just curious if anybody has done it yet.
Old Feb 5, 2009 | 07:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
In my opinion, a fan clutch conversion would be better than electric on these older vehicles.
Old Feb 5, 2009 | 08:00 PM
Dforgy's Avatar
Dforgy
That's another option I didnt think of.
Old Feb 5, 2009 | 08:02 PM
Jermafenser's Avatar
Jermafenser
I agree. Fan clutch is the way to go.
Old Feb 5, 2009 | 08:08 PM
2classics's Avatar
2classics
Depends what your using it for. Want to put electric one on my plow truck. No other way to get the fresh air all the time.
Old Feb 5, 2009 | 08:10 PM
Dforgy's Avatar
Dforgy
Even cost aside?
Old Feb 5, 2009 | 08:15 PM
Jermafenser
Originally Posted by Dforgy
Even cost aside?
Well, if you want to put that way - electric fans can be fabbed on the cheap using junkyard parts...but you probably would need to upgrade some electrical, many of them came with a puny-*** 40A or 65A alternator.
Many had a fan clutch from factory to begin with, so it's only a question of replacing it with OEM parts. Some non A/C trucks [like mine]had a belt-driven fan, so it's always spinning at full power. No parts to replace.
Old Feb 5, 2009 | 08:22 PM
Dforgy's Avatar
Dforgy
My parents own a salvage yard, but i'm not doing that conversion, just wanted to see what others thought.
Old Feb 5, 2009 | 09:17 PM
79f150toy's Avatar
79f150toy
I used a fan off a early 90s tbird. it was free, only took a hr to hookup and mount, and it is two speed. the high speed pulls about 4000cfm, which can cool off just about any engine. just my two cents...
Old Feb 5, 2009 | 09:22 PM
2classics's Avatar
2classics
Hey 79, what does that thing draw for amps?
Old Feb 5, 2009 | 09:27 PM
Thunderjet4x4's Avatar
Thunderjet4x4
I used to have dual electrics cooling my 429, worked great-until the relays wouldn't work on a hot day=no cooling.
I went back to the stock setup, with a factory flex fan, which is working good in cold weather, heh.
Plan on using overkill, good quality relays and have a backup system for hot weather, or other problems.
I will be using the electrics to supplement the mechanical fan, just to be sure. Torqueing around at low speeds with high compression especially can run hot fast.
+1 on a better alternator too!
Old Feb 5, 2009 | 11:56 PM
fmc400's Avatar
fmc400
MSEE
I did an electric fan conversion on my 79, straight six. It clicks on at 185F. I used a relay and a temperature sending unit. If you're interested in the specifics, I can look up the numbers. It works great...keeps things at a cool 190F.
Old Feb 6, 2009 | 12:14 AM
Dirt racer's Avatar
Dirt racer
I run an aluminum racing radiator and a black magic electric fan in my 75 F100 with a 429 It has an adjustable thermostat. Never had any cooling problems and warms up much faster in the winter. Been on there over 4 years now.
Old Feb 6, 2009 | 01:48 AM
bmarkline's Avatar
bmarkline
I had a black magic fan w/adjustible thermostat on my S-10. It burnt itself up after 60,000 miles...I mean there was only a fragment of one brush left. The others were gone! Bearings and shaft were black and blue! I have a Perma Cool now- seems to be better quality construction, time will tell.
Old Feb 6, 2009 | 02:13 AM
460's Avatar
460
Here's the only pic of the junkyard fan I picked up for $15. I got the relays, wiring harness/connector, and fuse with it also. The fuse is a 65 amp.
The fan fits almost perfectly on the radiator... the angle of the pic makes the fan look wider than it really is. I'll have mounted pics in a few days.
