01' Excursion/ $ 4k ?
Old Feb 5, 2009 | 03:13 PM
m350's Avatar
m350
I found an 01' Excursion Limited V-10 128k price is $4000. runs good,Went and looked at it,,it is a Repo,,Both Auto hubs are seized,,wont turn,,,has a dent in the r. rear qtr,,doors work good, glass is good,,a little rusty underneath,,no rot, no oil leaks from what I did see,,,I did not drive it,, one low beam is out, signals work, lights horn,,I should of pulled the tranny stick,, Damn,,the guy said it drives good, but he has only put about 10 miles on it,,,he said Buy it and Drive it Home !
How much are hubs?
Cant get into an Ex. much cheaper then that.
What you guys think ?
Old Feb 5, 2009 | 03:19 PM
soutthpaw's Avatar
soutthpaw
This must be it's twin in Chicago... Must be the going rate for them... Definitely where you can see the difference between Diesel and Gas versions... never lived back east, but I guess rust is a big issue
2000 ford excursion xlt 4x4
Old Feb 5, 2009 | 03:31 PM
BostonX73's Avatar
BostonX73
if it's just the auto hub, about $250 a side. if you need the hub assembly too - another $150, plus some seals probably. you can pull them and clean and lube them to see if that takes care of it too.
if you don't need auto, you can swap to a manual locking warn or milemarker hub for less $$
I was reading this link yesterday - thinking I should do mine Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
price is good on the truck if the motor is solid and those are the only other issues, esp for a limited.
eBay Motors: 2 FRONT HUB BEARING FORD F250 F350 F450 F550 SUPER DUTY (item 120321389436 end time Feb-17-09 10:47:12 PST)
eBay Motors: 1999-2004 Ford F250 F550 Excursion New Auto Lock Hub OE (item 230322546010 end time Feb-28-09 12:13:07 PST)
Old Feb 5, 2009 | 09:09 PM
moto4's Avatar
moto4
My guess would be that the maintenance was probably not at the level it should have been, and with 128k, the tranny would be my main concern.
Old Feb 5, 2009 | 10:49 PM
Monsta's Avatar
Monsta
Sit. Stay.
4 grand?? Heck, I'd buy it. You can get it up to snuff for less than $1K and sell it for $7K. Easy $2K.
Heck, where is it? I'll buy it!
Old Feb 6, 2009 | 05:48 AM
YellowSled's Avatar
YellowSled
id go for it then put a few weekends of work into it.
Old Feb 6, 2009 | 09:41 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Yeah me too, it doesn't sound like anything you can't handle. Drive it and see how it feels.
Old Feb 6, 2009 | 11:35 AM
bigdaddymedic2000's Avatar
bigdaddymedic2000
i just replaced the front hubs on my ex .... warn manuals $194.00 (napa), labor $20.00 ... to have 4 x 4 again priceless
Old Feb 6, 2009 | 01:21 PM
Monsta's Avatar
Monsta
Sit. Stay.
Shoot if the hubs won't turn that could easily be fixed with WD-40! Mine froze once. I cleaned them up and never had another problem with them.
Old Feb 6, 2009 | 02:26 PM
m350's Avatar
m350
Opps,,I just remembered,,,it also needs a driver seat belt( repo man cut it to tie the steering wheel he said),,and the pass side tow mirror is messed up,,glass is in it,,but has several layers of black tape around and around it to hold it in.
Are Excursion's able to be towed ? (must have had the back up,,if they had to tie the steering wheel,,?)
Old Feb 6, 2009 | 02:59 PM
Vijay's Avatar
Vijay
where is it!!!!
Old Feb 9, 2009 | 06:23 AM
YellowSled's Avatar
YellowSled
Post the pics already...
Old Feb 25, 2009 | 04:47 PM
m350's Avatar
m350
Wow I posted this 20 days ago,,,,Can't believe The man still has the Excursion for sale,,,Got the cash up,,,Trailer is already to Go,,He said he will be there in the Morning around 9:am,,Going to leave here around 7:30 am,,,the Ex is about 95 miles away,,,told him I want to drive it,,and look it over again before, the deal is done !,,,,So looks like I have a Good chance to own a 01' Excursion Limited,V-10, Deep Wedgewood Blue/Tan, needs a little work but think the price is OK,,as long as all checks out in the AM,,,will Get pics if it comes home with us ! Later,,,,Mark
Old Feb 26, 2009 | 07:10 AM
Toreador_Diesel
Eggcelent.......good luck!
Old Feb 26, 2009 | 10:17 AM
Cardiac69's Avatar
Cardiac69
If he has had it for sale that long, it's time to offer $3k....
