Exhaust Brake Help?
EDIT: The new album is uploaded.
Oh Yeah I forgot....https://www.ford-trucks.com/forums/a...hp?albumid=281
Yellow arrow- what the crap is this? I'm guessing it is a part of your exhaust brake... its definitely not stock
Blue arrow- wiring/relay most likely for your exhaust brake. Follow these wires to figure out where they go (make sure they are hooked up)
Green arrow- this is the air line for the brake I'm guessing. One end should hook to something back near the turbo, the other end should hook to a compressor somewhere. Figure out where the lines go and make sure its all hooked up.
You mentioned the yellow wire is for your pyro- please tell me you didn't put it in the down pipe... (down pipe- the part of the exhaust that hooks to the turbo, just in case you didn't know that already)
This is likely the compressor for the brake. The wiring almost dead center in the pic looks to be all related to the brake, and you can also see the air line but I can't tell where it goes. I posted the link to BD's web site earlier in this post, I would check that page out and see if there is any helpful info there.
Check it out, lots of good info in there.
Taking pic's of the engine compartment isn't easy as the camera strap keeps tangling in my walker!! Just kidding I'm old...but don't have a walker yet!
And thanks for you know what!
By the way it is kind of hard to road test these things. I tried mine out going down a hill around my house and didn't really noticed a difference in the truck holding speed. So......I concluded from that that it takes a really heavy trailer or a very steep hill to really test out an exhaust brake, you can't really road test one otherwise. My opinion anyhow.
That's the actuator for the brake, you can see the air line going into it. Even with an empty truck if the brake closes you should be able to feel it, I know you can tell when the EBPV closes so I would think you could tell when the brake closes. Jeffrey is right though, with the brake closed the exhaust will not sound normal.
And I still see pyro wires going toward the down pipe, please tell me the pyro isn't in the down pipe!
Now I just got back from a test drive after reading the B&D Exhaust brake operating, and maint instructions on the link supplied by one illustrious SuperDuty. According to the instructions I now know why I thought my cruise control wasn't functioning properly. That was to be another thread. Everything seems to be as should be with the brake. And now the cruise is operating as it should too.
I'll be able to tell more when I'm actually packing a load. And believe me I can't wait to go haul hay to my barn this year. I just might have to look for a supplier that is farther away and lives on top of the mountains ...just for the fun of trying to see if I could possibly make this truck grunt.
At this point it seems to be a BIG DOUBT. Now to address Supers concern with my under hood wiring I added two close up pics of the turbo area and tubes. Superduty if you could go look I haven't figured out how to bring a single pic out of my album?
I called around and can get a new thermocouple for my gage for approx $ 46.00. But I don't want to order that then find out the gage is bad? SuperDuty tell me what you think on the wiring? Thanks again ...and now I know why I saw where somebody said these trucks could pull a house off it's foundation!
I haven't felt acceleration like that since I was 19 yoa and blew my1964 427, 425 Hp, 480 ft./lbs. at the axle Galaxy 500, 12.5 112 MPH 1/4 Stock.
If you like the SuperChip you'll have to ride in a DP Tuned truck sometime... everyone says it blows the SuperChip away. Mine is on its way
The yellow wire looks to be a pyrometer lead. The fact that its going this direction toward the down pipe makes me worried. The best place for the pyro is in the exhaust manifold, or the up-pipe just after the manifold. The EGT's in the down pipe are "diluted" by the turbo, and if you're not careful you can burn your motor up by relying on the post-turbo down pyro. You shouldn't need a new probe, just a drill bit, a tap, and a way to plug the hole in the down pipe. Unless whoever did the install put the Isspro post-turbo gauge in... what does the gauge look like?
See that doohicky almost dead center in the picture, just to the left of the black part? It's called an AIH and you can get rid of it if you want- search for "AIH delete" and you'll find tons of info. You can either plug the hole, or install a boost gauge fitting in its place.
To put your pics in a thread like I'm doing, all you need to do is:
Go to your album, find the pic you want
Rick click on the picture, and copy the "Address" info
When you are typing your reply, you can click on this:
if you use the standard reply page and follow the promptsIf you use quick reply, then it's a lot harder for me to explain how to put the pic in there, but if you really want me to I'll try to make my brain work harder
Also accidently ran into a "Dave" on another thread who is connected to B&D in someway. If he has time he might drop by here and better enlighten me as to what to expect from the exhaust brake when not under a load?
Thanks for the pic explanation. It won't let me "rep" you again. But you deserve it.
EDIT: I will save the AIH delete for a new boost gage.
And thanks again...learned something new!
I'll bet the Dave you ran into is the guy who works for or possibly owns B&D, I'm surprised he hasn't replied in this thread yet. Glad you've got things mostly figured out now
Spend some time reading the forums and looking around under the hood, you'll have more stuff figured out in no time. I just bought my stroker about a year ago and I've learned TONS in that year...enough that I recently went and got someone elses Powerstroker running after 3-4 guys had tried and failed! There's lots of other helpful PSD nuts like me in this forum to help out along the way
