Coolant leak
Old Feb 4, 2009 | 10:55 PM
tgore3's Avatar
tgore3
Coolant leak
Got a coolant leak, rear of engine, when it's cold only.
I suspect that metal haeter hose tube. What's back there as far as mounting/sealing? Do I need to pull the upper intake manifold to get at it good?
Thank You
Old Feb 5, 2009 | 02:20 AM
quicklook2's Avatar
quicklook2
get it pressure checked.
Old Feb 5, 2009 | 08:04 AM
tgore3's Avatar
tgore3
I already know it's leaking
It's got to be that metal heater hose tube or possibly the intake manifold, only things back there. Seals up once it gets hot.
Old Feb 5, 2009 | 08:39 AM
quicklook2's Avatar
quicklook2
you posted that you 'suspected' where it was leaking from.
do a pressure check to find out 'exactly' where.
Old Feb 5, 2009 | 08:58 AM
tgore3's Avatar
tgore3
You can't see back there
Old Feb 5, 2009 | 11:50 AM
quicklook2's Avatar
quicklook2
i am at a loss on how to help you with this.
good luck.
Old Feb 5, 2009 | 01:01 PM
Old93junk's Avatar
Old93junk
quicklook is right, get it pressure tested. even if you cant see the leak right now, it will become apparent when the pressure is applied. The fact that it quits leaking when it warms up says it probably a loose hose clamp some where.
Old Feb 5, 2009 | 01:15 PM
tgore3's Avatar
tgore3
I don't know why I though a heater hose went back there, must be my medication. Both heater hoses are forward of the intake. It's got to be the intake leaking, there's just nothing else back there. I already fixed the heater hose leak due to a loose worm clamp at the heater core.
That leak was right under the heater core. This one coming from rear center and i don't see anything leaking up front that could be running back.
I'll figure it out
Old Feb 5, 2009 | 01:37 PM
Old93junk's Avatar
Old93junk
Use a small mirror to see the back of the intake/ rear of engine. I dont remember, does the small block have a freeze plug on the back of the block?
Old Feb 5, 2009 | 01:38 PM
quicklook2's Avatar
quicklook2
rusted out freeze plugs.
with a running motor it is hard to see small leaks when running.
with a motor that is off it may not visibly leak.
thus the need for a pressure check.
Old Feb 5, 2009 | 01:46 PM
1966Tbird's Avatar
1966Tbird
i forget is there a coolant crossover at the rear of the intake maybe it's rusted/corroded through
Old Feb 7, 2009 | 04:09 AM
Chuck_Grodin's Avatar
Chuck_Grodin
Somebody say coolant leak?
Old Feb 7, 2009 | 05:57 AM
jr32560's Avatar
jr32560
hey buddy if you have access to a pressure tester use it-quicklooks2 is right -when the motor runs it is very hard to see a leak! but not running and cold easy!or easier! good luck---good call quicklooks2! would have been my 1st suggestion!hope he gets it straight!
Old Feb 7, 2009 | 05:59 AM
jr32560's Avatar
jr32560
yup sure did!!!
Old Feb 7, 2009 | 06:12 AM
tgore3's Avatar
tgore3
I know nothing of this "pressure testing", I'm assuming that would require someone else to touch the truck which doesn't happen, unless it's a tire/wheel guy. I've done all my own machanicin' since I was a teenager. I'm not meaning that statement in a bad way or anything toward anyone.
Let's say I took it to be pressure tested, you still can't get back there behind that intake in no mans land to see the leak anyways, or am I just way off base?
It doesn't leak when it's hot, so it would need to be tested when it's cold.
I'm almost sure if I popped of that upper plenum I'd be able find whatever it is. I'm not seeing any crossover tube back there that i can tell. i guess I could rig my own cap or maybe you can buy one to put some pressure on the system while it's cold and I have the plenum off.
I'm still trying to find the mystery exhaust leak on a daily basis as well.
