Opinions Wanted!
Old Feb 4, 2009 | 10:03 PM
joef1812's Avatar
joef1812
Opinions Wanted!
hello.
This is my first post to this board and i am looking for opinions and ideas for my "new" truck. I just bought (for a really good deal) a 77 F-150. I got it running and have found out the 400 cid that is in the truck is pretty worn out and the c6 trans needs some help too. I have operated several trucks with the 300 in them and would love to put on in this truck and i have found a rebuilt long block that i can get pretty cheap since the truck it was built for is now totaled. I would like to put that 300 in the truck and put a 5 speed behind it. I need to ask what 5 speeds i can put with it and if i can use the NP 205 trasfer case with them, i know you can use it if you use a ZF 5 speed from a truck with a 460. I am also currious if anyone has done such a swap and what problems have you run into. I would also like to know if anyone has any good ideas on upgrades that would be good for the engine (it is carbed not EFI but i may out EFI in someday) before i put it in the truck, such as camshafts, heads, manifolds ect.
let me know what you all think.
Joe
Old Feb 5, 2009 | 11:28 AM
Harte3's Avatar
Harte3
Probably have to use a ZF from a small block. As far as engine upgrades go, sit back and do a lot of reading on this Forum and here Fordsix Performance :: View Forum - 240-300 "Big Block" Six Performance
Old Feb 8, 2009 | 04:54 PM
muscletruck7379's Avatar
muscletruck7379
I would personally stick with a 4 speed, I have owned 2 np435's and one 5 speed in my 88. you would have to build a hydraulic clutch setup for it, and i have yet to see one that actually last.
my 88 has 155k and its tranny already needs synchro's. my bronco still shifts like new...
by the time you buy a transmission and get the conversion to work, you could have bought a dualrange(personal favorite) or gearvendors to go behind the 4 speed and be able to split gears.
although if you must i would suggest the np4500.
as for engine upgrades, efi head is good, 4bbl manifold, headers or efi exhaust manifolds. and a lower torque camshaft such as the ones sold for 4x4's should get you started.
The other Joe
16
May 13, 2014 08:55 PM
Harfend
18
Feb 2, 2011 10:47 AM
monsterbaby
104
Oct 10, 2006 05:05 PM
Big_Joe
Engine Swaps
May 27, 2006 11:34 PM
carmello
May 20, 2000 08:32 AM
