It will only put out 9-11psi and 30gph, which is alittle higher on the psi and the same GPH as the stock pump. The Holley Red that some run pump over 100GPH, which means that about 90% of the fuel is being returned to the tank. Kind of a waste to me? It might also explain why there have been more failures with them. We have also found that running the Facet up in the engine compartment and using a heavy % of WMO may be a problem. Most are putting them down on the frame near the selector valve.Here's the info on the pump:• Self-priming with a 10 ft. minimum lift• Check valve• 4 hour dry run• Self-regulating• 30 GPH• 11.5 - 9 PSI• VCA approved EC 95/54• 80 Micron Stainless Steel Filter• Transient Protection• State-of-the-Art Electronic• Sealed Electronics• Reverse Polarity Protection• Corrosion Resistant over 100 hours salt spray• Durable Transparent fuel bowl• Light Weight - 3LBs at 7 1/4”• Low Power Requirements 1.4 amp on average
If the block-off plate has a bowtie on it it has to be chrome. That way the 5 hp you gain is off-set by the 5hp loss of the bowtie.
It's simple truckenomics.
Actually I don't believe a word of my own B.S. since I have 4 GM trucks I like just fine. Sure they ain't Dodges or Fords but they get the job done. I just don't ask as much out of them.
I ordered the Dura-lift pump today. So by hooking up my elect. pump and taking off the mech pump ,using a block off plate. Will I be in danger off flooding the crankcase if the motor is off and pump on? what? I putting a switch on the dash for the pump?
