79 400 engine numbers
Old Feb 4, 2009 | 05:16 PM
countryboy6074's Avatar
countryboy6074
Newbie here! Anyone know the stock specs off a 79 150 with a 400? Also, can anyone tell me what the one that i bought and put in it might have? and the compression ratio it might have? Thanks for any input!
bored .40 over
aftermarket dished pistons
stock cam
edelbrock performer intake
edelbrock 600 cfm carb
stock heads
Old Feb 5, 2009 | 06:47 AM
MBDiagMan's Avatar
MBDiagMan
Specs for what parameters? If the engine is stock, it will have about 8.4:1 compression ratio.
Old Feb 5, 2009 | 09:49 AM
hollenjoe's Avatar
hollenjoe
MBDiagMan is right, that should be your cr, besides that, I asume the specs on the bottom of your post are from the engine you bought, so, with those specs you shoulb be having around 220hp and maybe 390lbs of torque, you should consider getting some headers and an aftermarket rv cam with a straight up timming chain, which are not that expensive. Having done that you would bump your engine around to 300 hp and 430 lbs of torque...
Old Feb 5, 2009 | 06:37 PM
countryboy6074
thanks guys
Old Feb 5, 2009 | 06:38 PM
countryboy6074
btw, any suggestions on cams? i will be getting some headers
Old Feb 6, 2009 | 05:02 PM
mustang81's Avatar
mustang81
according to my books the 400 in 1974 had 170 hp @ 3400rpm and 330 lb/ft @2000rpm
1975-78 158 hp @ 4000rpm and 276 lb/ft @2000rpm
SAE Net. Just for comparaison
the 351c 1971 240 hp @4600rpm(2v) and 350 lb/ft @2600. When they change the calculation for SAE Net in 1972 the 351c 1972 is 177hp @4000(2v) and 284 lb/ft @2000 rpm
Old Feb 6, 2009 | 05:08 PM
mustang81's Avatar
mustang81
according to my books the 400 in 1974 had 170 hp @ 3400rpm and 330 lb/ft @2000rpm. 1975-78 158 hp @ 4000rpm and 276 lb/ft @2000rpm. SAE Net.
the compression for the 400 is 8.0:1 except in 1972 is 9.0:1
79super460
Nov 17, 2012 07:13 AM
79Montanalariat
Apr 22, 2012 09:59 PM
j74250
Nov 29, 2008 12:10 AM
Colo79Ford
Oct 7, 2008 11:27 AM
COLEnMICHAELS66
Sep 11, 2007 02:45 AM
