Sponsored by: Real Truck
Disappointing 5.4L MPG
Old Feb 4, 2009 | 02:27 PM
beeser's Avatar
beeser
I've had my new to me '04 F250, 5.4L for a while now and my gas mileage is a disappointing 11 mpg of combined city and highway driving. I just stopped by our local Ford dealership and they didn't seem too surprised with the results. They said a major tuneup might help a little but it won't be a night and day improvement. What do you folks think? Should I get the $650 tuneup? Does the price seem about right?
'04 F250 Super Duty, Extended Cab
2WD
5.4L with automatic transmission
Truck has about 135,000 miles on it and I think (but not sure) there was a tune up before.
Old Feb 4, 2009 | 02:34 PM
smlford's Avatar
smlford
$650 for a tune up?
That doesn't sound right to me...
Old Feb 4, 2009 | 02:45 PM
stumpbuster's Avatar
stumpbuster
find out their version of a tuneup, then get the parts somewhere else and do it yerself.
sounds high
Old Feb 4, 2009 | 02:46 PM
senix's Avatar
senix
that is high...change the plugs yourself and put a new air cleaner on it. you can do the fuel filters too. All for less than 200.00
And no it will not help. I had a 06F250 with the 5.4. Was slightly better. Ran 3.73 gears.
It is what it is.
Old Feb 4, 2009 | 02:48 PM
25thmustang's Avatar
25thmustang
That does sound low.
I would say a tune up will not hurt, whether it helps or not is up in the air.
Check your tire pressure, run them a little high for slightly better mileage.
Check your driving style, cruise RPM, etc...
Old Feb 4, 2009 | 02:52 PM
Downriver Thunder's Avatar
Downriver Thunder
Be happy with your mileage. I got 8.44 on my last tank.
Old Feb 4, 2009 | 02:58 PM
jlalanas's Avatar
jlalanas
I had an 04 f150 with the 5.4. It was a 4x4 and had 3.73 gears. It got about 14-15 on the highway when new, then put on bigger tires and it dropped into the 12s. I guess it really depends on what mix of driving you do and if the area is generally hilly or flat. I live in a realively flat area and did mostly highway driving just to give you some perspective on my #s.
Old Feb 4, 2009 | 03:11 PM
beeser's Avatar
beeser
The terrain around here in San Diego is very hilly so the transmission does a fair amount of hunting. The rear end has 3.73 gears. Here's what's included in the $650 tuneup.
Change plugs
Replace coil boots
Clean throttle body and injectors
I've changed plugs in my previous vehicles but all this talk about seized plugs on the 5.4L makes me a little nervous tackling the job myself. Am I being overly cautious? What's involved with cleaning throttle body and injectors.
Old Feb 4, 2009 | 03:50 PM
dkf's Avatar
dkf
I beleive the injectors are cleaned with a solvent they put in the fuel rail, not 100% shure as I never did it. The throttle body is easy to clean. Remove the throttle body and clean it good with carb cleaner.
You don't really have to worry about the plugs seizing. With the engine cool take the plugs out slowly. They will probably squeel a little on the way out but shouldn't seize on you.
IMO $650 isn't too bad considering its the dealer. The dealers prices are crazy, nature of the beast.
Old Feb 4, 2009 | 03:55 PM
wiingnut's Avatar
wiingnut
if your gonna do a tune up, do it yourself $650 for a TUNE UP!
Old Feb 4, 2009 | 04:05 PM
DAVE67FD's Avatar
DAVE67FD
Many things can be a result of your 11 mpg. Inacurate calculations, driving habits, tire size and pressure, extra weight in the bed/cab, stop and go trafic etc... you name it the list can go on. After a full tune and with 135k you may pick up a couple mpg. My 06 with 57k and manual shift on the highway can get up to about 16 or so.
The $650 is high but not out of the realm with some dealerships. I would hope to think the truck has already had a tune up at some point but if not it may make more of a difference than you think. Does the truck run well? any lack of power? if so do as others mentioned buy your parts and do yourself. If you don't feel comfortable have a local reputable shop do the work. They should be able to do it for about a couple hundred lower.
Old Feb 4, 2009 | 05:29 PM
twayneb's Avatar
twayneb
I get better mileage with my V-10 and 4.3 gears.
Old Feb 4, 2009 | 07:07 PM
akford351's Avatar
akford351
That's very high for a tune-up...
DIY. Shouldn't cost more than $150 for all the parts and its really not that bad changing out the plugs... the one on the back pass. side will be a pain but certainly doable.
Old Feb 4, 2009 | 07:12 PM
jac08f250's Avatar
jac08f250
I have 08 5.4l 4X4 crewcab auto with 3.73's and I avg 13 mpg. I have gotten 17-18 mpg on the highway crusing about 60-65 mph.
Old Feb 4, 2009 | 07:22 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I agree on almost all points! That does seem a little low on the MPG, that you could do the tune up cheaper yourself, and that $650 is probably about right for a dealer charge.
In the summer months I was consistently getting 14-15 with a record high of 17.6 (all interstate). Since winter hit, I've been getting 13-14, mostly closer to 13.
I'm going on my first real "highway" trip this weekend since I put a vacuum gauge in so we'll see how that pans out.
