i went out this mornin to start my truck and it made this grindin noise and i heard the starter spinnin but the motor didnt turn im pretty sure the bendix is worn out again for the 6th time in 3 months im at a loss i have no clue what is going on any help would be greatly apprieciate it i cant afford to keep sinking money into this truck and might actually cry if i have to sell it
It has been a very long time since I bought a starter myself, but I have heard from a mechanic friend of mine that the quality of "remanufactured" starters has been terrible for several years now. His shop has stopped buying them and only buys new starters now. For some older cars, you can't get new ones anymore. I don't know if that is your problem or not.
Another possible problem is the ring gear on your flyweel. Have you checked it? If you have some F***ed up teeth on the ring gear, it will destroy starters quickly.
how hard is it to get the trans off to get to the ring gear and also can i just change the ring gear or do i need a new flexplate
im in college and money is tight and possibly needing a trans im getting to the point where ive got to much money into it
It's relatively easy if you have a tranny jack to remove. If not it can be a serious pain. It's not always easy to "re-stab" them or line them back up.
You won't really be able to tell if you need a new flexplate or not untill you get it apart. If the flexplate has cracks in it you will need to replace it etc...
As for starters, I've replaced two starters in the past several months. But I have lifetime warantee on them. The remanufactured starters are not as good as they used to be.
You might try getting a new or rebuilt one from Ford. The quality of those starters should be vastly superior.
Part Number: E4DZ-11002-BRM, not sure if the part number has been updated or not.
If you have a couple teeth missing on the flexplate, that probably says something about the condition of the rest of the teeth. If they are bad, they can ruin the starter.
If your truck is 2wd, you could pull the tranny back yourself with a floor jack, although having a extra set of hands makes it a lot easier. Instead of taking the tranny completely out and setting it on the ground, you can drop the whole thing down till it comes out with the jack underneath the tranny, and then pull it back a little ways and then jack it back up till the tranny hits the floorboard, and that should keep it on there till you get the flexplate replaced.
Just keep an eye on the fan shroud and stuff up front, since the engine is going to lean back on the motor mounts. You want it to do this, so you can slide the tranny back and not hit the floorboard, but you don't want to crack the fan shroud.
Very good advice. I would think about unbolting the shroud from the radiator as well and leave it hanging to help prevent damage.
thnx for the help but now to throw a wrench into everything, the motor is from a 1992 lincoln mk vii and ive heard that for used different cuonter weights on the flexplate/flywheel (28 oz.,50 oz.) and i do not know which one this truck has in it when i rotate the motor over by hand i can see numbers on what looks to be the counter weight can i look those numbers up anywhere? and also when i jack up the trans what should i put the jack under i dont want to use the bellhousing because i heard that can warp it and at the same time i get a bad feeling about using the pan
