High Flow Cats
Old Apr 2, 2001 | 07:43 PM
fordsrus's Avatar
fordsrus
High Flow Cats
Whats a good High flow cat for my 300 6 cylinder. There is two cats on there now and I would like to remove them and put one on. Will one cat still pass the smog test?
Old May 14, 2001 | 02:31 PM
masterskeeter's Avatar
masterskeeter
High Flow Cats
You might want to be careful there. Technically your not supposed to mess with the cats. Look at the specs of the new cat to see if it can do the job of two. I've replaced my own cat with a high flow one from Bassani. But be warned they ain't cheap, around 325.00. They bolt directly to the headers.
Old May 21, 2001 | 01:55 PM
traildawg's Avatar
traildawg
High Flow Cats
THe stock front cat is nothing but a resonating chamber to preheat the exhaust gasses, while the second is the actual cat. Any 3-way cat with an air tube will effectively replace the original units.
For legalities, it depends on your location. I know in some places they do a visual inspection, and if you had 2 cat's stock and only a single now they'll fail you, even if you pass the sniffer test.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Lift w/35's
And STILL waiting to get my 4.30 gears installed!!!!
http://www.geocities.com/ProjectTrailDawg
Old May 23, 2001 | 06:34 PM
MSTRAWN's Avatar
MSTRAWN
High Flow Cats
