Trying to identify some headers that were given to me when I bought a used engine for core purposes. Exhaust port spacing is 4.5". The bolts are offset high and low on either side of the port, with the bolt closest to the front of the engine being low and the other being high on each cylinder. Does anyone have a clue as to what engine this might fit, or if it even sounds like a Ford application? They are for a V-8 engine, and the ports seem to be larger than the smallblock headers that I have seen.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy C intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals, turbos, tips, and 02's
MSD6A w/Blaster Coil
Headlight relay system (Delanty style)
Overhead Mount FM-CD etc.
R-134 A/C system (I'm cool)
Armed with that information, I did some research. You are right, they are 351M 400 headers. Too bad they dont fit anything that I have. Thanks, Michael
1977 F-100
