351 heads
Old Feb 4, 2009 | 07:52 AM
z1121jack's Avatar
z1121jack
351 heads
Just put my 1984 351w in a machine shop to have the engine balanced. am almost ready to begin rebuild, Have purchased a lot of the parts but am still confused about a few important things:
Selecting after market heads, camshaft and intake manifold. I realize that they are interdependent but where to start? I'm guessing that head selection should come first
I want the 351w for a street rod with around 350 hp and mid level rpm power range. The best prices I have found online are on EBay What combustion chamber size do I use.? Any suggestions on comb. chamber size or heads in general appreciated.
Old Feb 4, 2009 | 08:03 AM
Conanski's Avatar
Conanski
Look at the Edelbrock package, that wll give you an idea of what to use.
Old Feb 4, 2009 | 08:24 AM
z1121jack's Avatar
z1121jack
thanks conanski
Old Feb 4, 2009 | 08:31 AM
z1121jack's Avatar
z1121jack
I don't know which edelbrock package to look at that's the proglem
there are lots of "packages" avalable but i still do not know about cobustion chamber size, etc
Old Feb 4, 2009 | 09:21 AM
MBDiagMan's Avatar
MBDiagMan
What pistons are you using? Dished? Domed? Flat tops? That will be necessary to consider when selecting Head combustion chamber volume.
You don't say much about your street rod. How heavy is it? What transmission? What gear ratio?
Old Feb 4, 2009 | 09:40 AM
z1121jack's Avatar
z1121jack
pistons are dished. c6 tran in an f1 still going to change rear end so I don't know gear ratio.
