Starting problems
Old Feb 4, 2009 | 05:50 AM
jsimpson's Avatar
jsimpson
Starting problems
When cold or warm, my truck will start only by releasing the key as soon as the engine begins to fire. When it's hot it acts like a flooded engine and has to sit for atleast fifteen minutes before it will start. I've searched and found two possibilities: ruptured fuel pressure regulator diaphram or weak ignition module. The engine runs rich all of the time, so I'm leaning toward fuel pressure regulator. But it runs great once it's started. What say you?
89 5.8 EFI ex NJ Bell bucket truck
Eustis, FL
Old Feb 4, 2009 | 06:59 AM
jr32560's Avatar
jr32560
I had an old 78 had almost the same problem on the release switch start thing it was the ignition switch-it had in dash type ours is on the column half way down the steering column-hope this helps?
Old Feb 4, 2009 | 11:52 AM
jsimpson's Avatar
jsimpson
Thanks. It turns over fine with the ignition turned to "start", but the engine won't catch until I release the switch. Acts like it's getting too much fuel or too little spark. Battery is good.
Alm200
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 23, 2015 05:20 PM
vietnamvet
Jan 6, 2013 03:07 PM
TCB-1
Florida Chapter
Apr 18, 2010 09:27 PM
