U joints
Old Feb 3, 2009 | 10:18 PM
86302f150's Avatar
86302f150
yep its a 117"" wheelbase
Old Feb 4, 2009 | 12:02 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Sorry it took so long...
I need to know the size of the bearing caps.
Are they the same exact size, front and rear on all bearing caps?
1.125"?
Old Feb 4, 2009 | 12:26 AM
86302f150's Avatar
86302f150
I'll go measure em and let ya know
Old Feb 4, 2009 | 12:36 AM
86302f150's Avatar
86302f150
In lieu of having a micrometer the caps need to fit the holes as follows.
Rear Shaft -1 1/8
Rear to U-bolt - 1''
Front Shaft - 1 1/8
Tranny yoke - 1 1/8
all these are press fit , not with the spring clip thats supposed to go in there. the u joints I have right now are too big to press into the holes and allow the clips to go in
Old Feb 4, 2009 | 12:38 AM
81-F-150-Explorer
The book is saying it could have three different types.
1 with all 1-1/8 (1.125" caps)
1 with all 1-1/16 (1.063" caps)
or
1 with 2 of each size.
Old Feb 4, 2009 | 12:43 AM
86302f150's Avatar
86302f150
and that exactly what autosmack gave me.... 1 with 3 of each sizes.. but they claim its all they carry so now I need to find a parts store that carries 1.125 press fit caps and eliminate the snap rings
Old Feb 4, 2009 | 12:46 AM
flamebuster's Avatar
flamebuster
All else fails your idea to take the old one in will get you the part your after. I am partial to napa or other big name supplier they can get the right part with a caliper measurment of the caps and width of the cross.
Old Feb 4, 2009 | 12:51 AM
86302f150's Avatar
86302f150
yeah I think im going to return the "Brute Force" u joints to AZ and take the shaft to Napa to have em check the sizes and see what they have. last thing I need is to have the driveshaft fall out on me when driving
Old Feb 4, 2009 | 01:16 AM
81-F-150-Explorer
I agree there. There is no way to really know if the shaft and parts are original or not unless you bought it new.
Old Feb 4, 2009 | 02:18 AM
srercrcr's Avatar
srercrcr
Check the AZ website and do your own research
Old Feb 4, 2009 | 05:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 86302f150
its an 86 f-150 with the 5.0 EFI regular cab regular bed (117" W.B), 2wd with a AOD.
As original for your application:
Ford part number: C3AZ4635L / Timken part number: 51203 .. U-Joint
#1330 / 3 5/8" span / Inside Locks (Mechanics aka Cleveland Design)
Cup O.D. (4) 1 1/16" // Cup I.D. (4) 11/16"
Ford part number: C3AZ4635H / Timken part number: 51204 / Dana-Spicer part number: 5409X .. U-Joint
Cup O.D. (2) 1 1/16" (2) 1 1/8" // Cup I.D. (4) 11/16"
Info source: 1980/89 Ford Light Truck Parts Catalog ~ Driveshaft Application Charts ~ Text ~ Section 46.2, Page 12.
In order to find the correct U-Joints, you first have to look up the correct driveshaft. This is why I needed the exact wheelbase.
Old Feb 4, 2009 | 09:40 AM
Franklin2's Avatar
Franklin2
The Napa guys should be able to help you. I have mis-matched driveshafts and changed trannies before, and they have a Spicer book that has all kinds of weird adapter U-joints with all the measurements.
I used a old early 70's bronco slip joint assembly in the front driveshaft of my 80, and they had a u-joint that was narrow one way, and wide the other way to make it fit. If that u-joint ever goes out, that poor guy will be doing the same thing you are.
Old Feb 4, 2009 | 09:52 AM
  #28
86302f150's Avatar
86302f150
yep Napa has both but they have to order the front one, they have 3 of the rear ones in stock. someone should sticky this thread incase they ever run into this @#$%pile of a problem lol
Old Feb 4, 2009 | 12:31 PM
  #29
81-F-150-Explorer
Yep and those slip yokes are the easiest thing to replace and change too.
Glad you got it sorted.
Old Feb 4, 2009 | 12:51 PM
  #30
86302f150's Avatar
86302f150
thanks for all the info guys.. that tech data was invaulable
