possible tranny swap
Old Feb 2, 2009 | 08:38 PM
frostysdriver's Avatar
frostysdriver
can an 06 6 speed tranny bolt up to a 87 f250??
Old Feb 2, 2009 | 08:41 PM
joe f350's Avatar
joe f350
anything possibale
Old Feb 2, 2009 | 08:42 PM
frostysdriver
yea, but will it work with my 4x4, the transfer case, i just wanna make sure that if i do this it is solid and i can haul the horses
Old Feb 2, 2009 | 08:45 PM
joe f350's Avatar
joe f350
make shure its a 4x4 tranny
Old Feb 2, 2009 | 09:35 PM
Dean88's Avatar
Dean88
Hmm, I know the 6 speed behind the 99-02's will work to a point, the bellhousings were the same, but you won't have a speedo, but I don't know about an 06 because I don't know if the bellhousing of the 6.0's is the same as the 7.3
Old Feb 2, 2009 | 09:38 PM
joe f350's Avatar
joe f350
y wont he have a speedo
Old Feb 2, 2009 | 09:43 PM
Dean88's Avatar
Dean88
She won't have a speedo, because if I remember correctly because those new trucks have the speedo sensor in the rearend, not the tranny.
I really dont know much about the swap, i just remember dave talking about it
Old Feb 2, 2009 | 09:48 PM
Dean88's Avatar
Dean88
Why would you want a 6 speed, I just read in your sig that you have a 4spd with a Gearvendors unit. I would much rather have that than a 6 spd.
Old Feb 2, 2009 | 10:11 PM
frostysdriver
Even with the GV i dont go much faster than 55 because the rpms start to run high. I would actually like the 5 speed(it would be just like a 6 beacuse of the GV) but i might be able to get a deal on the 6 thats the only reason im asking, if i cant get the 6 to go in then i wont buy it.
I have a speedo sensor by the tranny, is that not what you were talking about?
Old Feb 2, 2009 | 10:15 PM
Dean88's Avatar
Dean88
Dang how what kind of rearend do you have, and are you sure the GV is shifting?
Also what are you calling too many RPMS??
Because mine runs at 3K rpms at 70 everywhere I go with no problems
Old Feb 2, 2009 | 10:21 PM
frostysdriver
at 70 im well over 3200. To me, thats just not a leisurely pace for cruising down the highway but thats IMO. Yes the GV is working. The tranny is geared low, i know they all are but this one must be lower than others? i can look now at what tranny i have on it, im about to go finish the clutch job. I havnt gone on the highway since the new tires so i dont know what kind of difference they have made.
Old Feb 2, 2009 | 10:38 PM
David85's Avatar
David85
You have an underdrive transmission, thats why the RPMs are so high. I didn't know gearvendors made an underdrive. Normally I would suggest a 3.08 axle ratio swap, but it seems that you have a 4wd by the look of your truck so that won't work.
Short answer is that a ZF6 will not work. The tailshaft is too big to match any of the transfer cases that are equipped with a speedometer cable drive. I heard that machining the tailshaft might be possible, but thats not something I can offer any real info with. Much better off swapping the underdrive for an overdrive or getting a ZF5.
Old Feb 2, 2009 | 10:44 PM
joe f350's Avatar
joe f350
what about puting the speed senor in the rear end
Old Feb 2, 2009 | 10:47 PM
Dean88's Avatar
Dean88
Well, to do that Joe, you would have to get a rearend out of of and SD, and then if I remember things right, the speed sensor in the dash would have to be swapped to an electronic one.
Old Feb 2, 2009 | 10:50 PM
Dean88's Avatar
Dean88
But wow frosty, yeah something is off, I'm not trying to call you a liar but I'm doubting your GV is working, cuz my GV doesn't work and thats almost where I run on RPM's to run 70, but I have 35's on my truck.
