looking at buying used wheels and tires?
Found on Craigslist some wheels and tires and had a few questions. First, here is what I am looking at.
WELD Rims 8x170
I went and looked and the wheels were in good shape. Nothing a little pollish wouldn't clean up. The center caps might need to be replaced. Not too expensive though. These are the wheels... Desert Rat :: CLOSEOUT ! Weld "Scorpio V" Wheels
Tires have about 1/4 to 1/3 tread left... ProComp All Terrain tires (315/75R16).
Now for the questions. Truck is stock suspension wise... If I get a front leveling kit will the tires fit without rubbing? Do you think it is a good deal? I pull a 5th wheel sometimes... will that make my truck too high?
Any input is great. I Know I could talk him down to $180-@200.... THANK YOU!!!
WELD Rims 8x170
315's may rub a little on the front drivers side with just a leveling kit. I know of at least 2 trucks including mine that do. I would also think about putting at least a 3 1/2 inch if not a 4 inch block in the back instead of the stack F250 block.
How much is the guy asking?
oreocreaming
13
07-22-2010 05:21 PM
