Modular V10 (6.8l)
E4od/4r100
Old Feb 2, 2009 | 02:18 PM
oldirtytruck's Avatar
oldirtytruck
Cool E4od/4r100
Ok, I went by the part store to inquire on the cost of a tranny filter for my 2003 F350. The man behind the conuter asked me the basic information; year, make, model, and engine.
The man behind the counter told me I needed a filter for a E40D transmission. I told him I have a 4R100 and he was like well it's not calling for that tranny . Now I'm not one to tell him he's full of crap cause now I'm confused. I was under the impression that E40D was used on 5.4 modular and the 4R100 was used on the 6.8 and diesels for that year. Am I right or is the man reading the parts screen right ?
Old Feb 2, 2009 | 03:41 PM
dkf's Avatar
dkf
The 4R100 was used on 5.4l, 6.8l and 7.3l in the 2003 model on Super Dutys.
Old Feb 2, 2009 | 03:49 PM
oldirtytruck
ok. So what about the E40D.
Old Feb 2, 2009 | 04:31 PM
dkf's Avatar
dkf
The E4OD was in the "Heavy Duty" Ford F-Series trucks prior to 98'. I don't really know much about the E4OD.
Old Feb 2, 2009 | 05:15 PM
oldirtytruck
Very true I had a 95 Ford with that tranny. It just threw me for for a loop when the guy told me that.
Thanks again
Old Feb 3, 2009 | 07:47 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
The E4OD and the 4R100 are the same transmission
It changed names somewhere. I always thought it was the difference between the "regular" tranny and the electronic one, but the E4OD was also electronic.
Same thing, different year.
I'm not surprised the parts books say "E4OD" on a filter.
Although, be careful. I think there might be a "deep pan" or "shallow pan" filter/strainer. Just make sure the new one looks just like the old one
Old Feb 3, 2009 | 07:57 AM
oldirtytruck
Well, well, now the mystery is solved. Thanks for clearing that up.
Old Feb 3, 2009 | 08:25 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
In '98-'99 Ford made several upgrades to the E4OD. The internals were stronger to live behind the higher power diesel that came with the '99 Superduty. They also changed the case to mate to the modular engines (only on the gas versions,) and they added turbine speed and output speed sensors. This is where the name change happened.
Old Feb 3, 2009 | 08:53 AM
krewat's Avatar
krewat
Thanks Mark, there had to be SOME reason for it. And, it makes the name somewhat decipherable compared to the 4R70W and others.
But the filter/strainer is still the same, eh?
Old Feb 3, 2009 | 10:03 AM
dkf's Avatar
dkf
I learned something new today. I never was familier with the E4OD, thanks for the clarification.
Old Feb 3, 2009 | 10:10 AM
oldirtytruck
Thanks Mark
2003 F-350 XLT FX4 V10
Old Feb 3, 2009 | 03:18 PM
Mark Kovalsky
I believe the filters are the same.
Old Feb 3, 2009 | 05:29 PM
Monster-4's Avatar
Monster-4
According to Rock Auto's catalog there are four different part numbers:
YC3Z7A098AA
YC3Z7A098BA
4C3Z7B155AA
F81Z7A098AB
YC3Z7A098AA is the same filter for the E40D and 4R100. Not sure why so many differnt filters but these where all listed for a 2003 6.8L V10.
Edit: On second glance YC3Z7A098AA and YC3Z7A098BA are both listed for the E40D and 4R100.
Old Feb 5, 2009 | 08:00 AM
SLE's Avatar
SLE
I don't want to hijack this thread but it seems as though I finnally found someone that knows the differences. My questions is I'm trying to figure out why my 03' 4R100 with 373's and 16" 285s turns a ton of rpms less then my dads 93 7.5L F350 2wd dually with 4.10's and of course a smaller tire. I know his will turn more rpms but the difference is like 1200 rpms when we are each in the same gear, so something doesn't make sense unless the trany gears are considerably different ratios which I thought the E4OD and the 4R100 used the same ratios???? The only thing I cann't remember for sure is his tire size but it seems to me that it's a 16" 245, but I could be wrong! any ideas?
Old Feb 5, 2009 | 08:18 AM
oldirtytruck
I don't have an answer for that. I have the same set up as you but my tires are 265's and I never go pass 2300 rpm's unless im above 70mph or I standing on the gas.
Hope this helps you at least. My automatic compared to the numbers on the chart below are about 900rpm less... but it is stats for a manuel tranny in 4th with 1:1 gears @65mph.
Highway Driving, Good Fuel Economy
Daily Driver, Best Overall Performance
Most Power and Towing, Reduced Fuel Economy
This chart is based on 65 MPH and a gear ratio of 1:1, on a manual transmission in 4th gear. Please NOTE: If you have an automatic transmission your RPM will higher due to slippage in the transmission and the torque converter. With an overdrive transmission your RPM in overdrive will be 15% to 30% less than indicated.
Gear Ratio
.......2.35 2.73 2.94 3.07 3.21 3.31 3.42....3.55 3.73 3.91 4.11 4.27 4.56... 4.88 5.13 5.29 ..5.38 5.71 6.17 7.17
22 2333 2710 2919 3048 3178 3286 3395 3524 3703 3882 4080 4239 4527 4845 5093 5252 5341 5668 6125 7118
23 2231 2592 2792 2915 3048 3143 3248 3371 3542 3713 3903 4055 4330 4634 4871 5023 5109 5422 5859 6808
24 2139 2484 2675 2794 2921 3012 3112 3231 3394 3558 3740 3886 4150 4441 4668 4814 4896 5196 5615 6525
25 2053 2385 2568 2682 2804 2892 2988 3101 3259 3416 3590 3730 3984 4263 4482 4621 4700 4988 5390 6264
26 1974 2293 2470 2579 2696 2780 2873 2982 3133 3284 3452 3587 3830 4099 4309 4444 4519 4796 5183 6023
27 1901 2208 2378 2483 2597 2677 2766 2872 3017 3163 3325 3454 3689 3947 4150 4279 4352 4619 4991 5800
28 1833 2129 2293 2395 2504 2582 2668 2769 2909 3050 3206 3331 3557 3806 4001 4126 4196 4454 4813 5593
29 1770 2056 2214 2312 2417 2493 2576 2674 2809 2945 3095 3216 3434 3675 3863 3984 4052 4300 4647 5400
30 1711 1987 2140 2235 2337 2410 2490 2584 2715 2846 2992 3109 3320 3553 3735 3851 3917 4157 4492 5220
31 1656 1923 2071 2163 2261 2332 2409 2501 2628 2755 2896 3008 3213 3438 3614 3727 3790 4023 4347 5051
32 1604 1863 2007 2095 2191 2259 2334 2423 2546 2669 2805 2914 3112 3331 3501 3610 3672 3897 4211 4894
33 1555 1807 1946 2032 2124 2191 2263 2349 2469 2588 2720 2826 3018 3230 3395 3501 3561 3779 4083 4745
34 1510 1754 1889 1972 2062 2126 2197 2280 2396 2512 2640 2743 2929 3135 3295 3398 3456 3668 3963 4606
35 1466 1704 1835 1916 2003 2065 2134 2215 2328 2440 2565 2664 2845 3045 3201 3301 3357 3563 3850 4474
36 1426 1656 1784 1862 1947 2008 2075 2154 2263 2372 2493 2590 2766 2961 3112 3209 3264 3464 3743 4350
37 1387 1611 1735 1812 1895 1954 2019 2095 2202 2308 2426 2520 2692 2881 3028 3123 3176 3370 3642 4232
38 1351 1569 1690 1764 1845 1902 1966 2040 2144 2247 2362 2454 2621 2805 2948 3040 3092 3282 3546 4121
39 1316 1529 1646 1719 1798 1854 1915 1988 2089 2190 2302 2391 2554 2733 2873 2962 3013 3198 3455 4015
40 1283 1491 1605 1676 1753 1807 1867 1938 2037 2135 2244 2331 2490 2664 2801 2888 2937 3118 3369 3915
41 1252 1454 1566 1635 1710 1763 1822 1891 1987 2083 2189 2275 2492 2599 2733 2818 2866 3042 3287 3819
42 1222 1420 1529 1596 1669 1721 1778 1846 1940 2033 2137 2220 2371 2538 2668 2751 2798 2969 3208 3728
43 1194 1387 1493 1559 1630 1681 1737 1803 1894 1986 2087 2169 2316 2479 2606 2687 2733 2900 3134 3642
44 1166 1355 1459 1524 1593 1643 1698 1762 1851 1941 2040 2119 2263 2422 2545 2626 2670 2834 3063 3559
