Leaking Tank
Old Mar 24, 2009 | 02:37 PM
David85's Avatar
David85
I had to repair my rear tank late last year. Dropped it, emptied it, then cleaned the pitted area the best I could using a wire wheel in a 5" angle grinder (gloves and full face protection is not a bad idea). Soldered it with a small butane torch (to each his own), then cleaned the flux off with solvent and a wire brush. Then used epoxy tank sealer to cover up the solder patch. The idea was to protect corrosion from ruining the bond. After all was done I undercoated the whole tank with a parafin wax undercoating.
As it turns out, the OBS powerstrokes started using plastic fuel tanks, so that will be what I'll get when I have to patch a tank again.
Old Mar 24, 2009 | 07:34 PM
roamer37's Avatar
roamer37
I have welded 100s of gas tanks. The prescribed method is to take it out side fill it with soap and water put a air hose with a small orifice in it.. let the bubbles take out the fuel it takes a day or so but when its done its safe..
Old Mar 24, 2009 | 09:04 PM
archangel's Avatar
archangel
Any of you guys know what tank I could use to replace a rear tank on my 1991 diesel that would have more capacity?
Perhaps the same year 38 gallon bronco tank?
I know it is a "gasoline" fuel tank, but wonder if the diesel sender would fit the hole and I could just extend the pick up and the sender arm to fit the deeper tank.
My gasoline fuel line tools and plugs fit the diesel lines, so I know the fuel lines will fit.
I need to replace it before the front starts to leak, although it did look like it was in fairly decent shape last year when I pulled it for inspection and to reinstall that round pick up tube flapper that fell out causing it to suck air at 1/4 full tank.
Old Mar 24, 2009 | 09:57 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I've watched my father braze many tanks, He fills them plumb full of gas (No air/fume pockets) Lights them on fire and goes to brazing...
In the wrecking yard I worked in as a kid, my boss used to stand on the trunk, drop the torch to the filler pipe... Seen him (all 6.6" @ 340lbs) go flying a couple of times.
Not Me, never had the b....
-Enjoy
fh : )_~
Old Mar 24, 2009 | 10:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I have a 44 gallon rear tank that I bought through the local radiator shop.
Can't remember who the manufacturer was, and the name is under the skid plates so I can't see it.
Old Mar 24, 2009 | 11:57 PM
David85's Avatar
David85
-Enjoy
fh : )_~
LMAO!!! I don't like gasoline, never touch the stuff.
Old Mar 25, 2009 | 06:47 PM
Dave Sponaugle
Putting a torch on a tank full of gasoline, I can't say my opinion on that on here.
A diesel tank, that is a lot different story unless it is over 100 degrees, then I would be a bit leary.
Saw a guy try using a Bic lighter to see in a semi fuel tank one night after he had been driving for several hours.
The return happened to be in the tank he tried to see in, the vapors from the hot return line fuel did ignite and he did get a hair trim whae it flashed out around his head.
Compounded many times by the fact he was trying to see in the tank.
But after the initial flash, the vapor was gone and the fire went out.
That story would have been much worse if it would have been a tank of gasoline.
Old Mar 25, 2009 | 07:58 PM
starmilt's Avatar
starmilt
This makes me think you should have to pass a common sense test to ride a bicycle on the street much less drive a truck. lol
But I saw a construction (dirt) super. do the same thing one time. Go figgure.
Old Mar 25, 2009 | 10:02 PM
Festus Hagen
Methanoholic
I was on my way home from Football practice one night and my 1968 Belvedere 318 over heated... What do I do, pull over and pop the hood, rad cap and stuck my lighter in the rad to see if I could see coolant... What a pretty blue/green flame at night!
Never done that again!
I was only 16...
-Enjoy
fh : )_~
Old Mar 25, 2009 | 10:09 PM
David85's Avatar
David85
I set off a small metal container of diesel on the floor of the shop just to see how flamable it really was. Guessing a few tablespoons of the stuff. Took about 5 seconds with a propane torch to get it going, and even then, it wasn't a big deal. What was a little supprising is just how hot it was though after only a few seconds of burning.
It wasn't very hot that day, and the concrete floor was cool and in the shade, so that also plays a role. In direct sunlight on a hot summer day, I would certainly conisder a diesel container a fire hazard. Gasoline in the same conditions? lets not go there.
Old Mar 25, 2009 | 10:24 PM
starmilt's Avatar
starmilt
Gasoline isn't near as explosive as it used to be. We used to use it to air up truck and heavy equipment tires try it with todays gas it won't happen.
Old Mar 25, 2009 | 10:36 PM
Dave Sponaugle
I have seen guys set a pan with a little gasoline in it on the floor and toss matches in it.
Below about 45 degrees, the gasoline usually puts the match out.
From 45 to about 75, instant fire
Above 75, the higher it is above 75 the farther you better be from the pan when the match hits.
  #28
Festus Hagen
Methanoholic
Ether is the only way to get some of them big tires to bead up.
-Enjoy
fh : )_~
