fuel pressure gauge
Old Feb 1, 2009 | 09:19 PM
Beamed's Avatar
Beamed
fuel pressure gauge
i want to insatll a fuel pressure gauge what do i tap into and what type of gauge should i buy. also have any of u guys installed a electric fan on ur trucks if so what type of fan did u use, does it come on by itself, and how much did the whole thing run u in the pocket thanks
Old Feb 1, 2009 | 09:27 PM
khadma's Avatar
khadma
Carpenter Local 745
Here is a link to an Efan installation.
https://www.ford-trucks.com/forums/7...n-install.html
BTW, why do you need a fuel pressure gauge?
Could you list your truck or at least give us some info - EFI?
Old Feb 1, 2009 | 09:35 PM
Beamed's Avatar
Beamed
aw sheet i keep forgetting to do that how do i set that up so it shows on the bottom of the post ive got a 94 f150 5.8 with efi
Old Feb 1, 2009 | 09:58 PM
khadma's Avatar
khadma
Carpenter Local 745
Look for the User CP in the blue banner.
Click on it and there will be a section to edit your signature. (under settings and options).
This is how you add information that will be on all your posts.
Give it a try!
Old Feb 1, 2009 | 11:04 PM
Beamed's Avatar
Beamed
thanks i should work now
Old Feb 2, 2009 | 12:52 AM
tgore3's Avatar
tgore3
You can just hook up a gauge to the port on the fuel rail. You can see it there on the driver's side of the intake. It looks like valve stem coming out of the shiney fuel rail feeding the injectors. Do you want to be able to see the pressure all the time or just check it under the hood?
There's like 3 options...0-60 or 0-100 psi gauge will be fine
1. mount mechanical gauge with shrader valve adapter directly on the fuel rail port...cheapest, but can only see under hood
2. connect a fuel line the port to somehwere like your cowl and mount a mechanical gauge where you can see it...little more cost and gauge mounted on truck
3. go digital with sending unit, either kit form, or select a gauge you like and buy a sending unit...pretty expensive but gauge can be mounted inside truck
you can go to Summit or Jeg's and check out the different gauges and parts. I don't recall the size of that shrader valve. I put a mechanical directly on my fuel rail when installed a supercharger and adjustable fuel pressure regulator on my 90 5.0 Mustang. I just needed the gauge there to adjust my fuel pressure.
I installed the 15" Black Magic electric fan on the Mustang. It's a direct fit units for those cars. It had adjustable t-stat built in to control it, also wired in to turn on when AC comes on, it used the bulb type sensor. There's a lot of options to an electric fan. Direct fit is going to be more expensive but they work well. You can get electric fans from a salvage yard and buy the controls seperately at the auto parts store. Same with a new universal fan. You can spend upwards of $500 on a good direct fit with dual fans that comes with everything you need, you're talking 5900cfm. You can scrounge parts and build your own for $100-$150 I'd say. A single you put together would use your existing shroud, the dual kit would replace that and cover the whole radiator.
Old Feb 2, 2009 | 02:17 AM
Beamed's Avatar
Beamed
yea thanks for the help guys especially tgore3 i plan on using two of the tarus fans with a controller kit from the ap store i just want a guage under the hood
Old Feb 2, 2009 | 08:03 AM
Conanski's Avatar
Conanski
Summit fluid filled gauge and NPT fittings from a local hardware store..
tjustice
Jul 23, 2012 08:42 PM
johnarahill
Jan 24, 2012 09:56 PM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 1, 2010 07:57 PM
jasontrucks76
Oct 7, 2009 03:38 PM
